Fluid Coolers in C6 Grand Sport
I am always trying to learn as much as I can about my car. In doing so, I have some questions.
How many fluid coolers does a 2011 C6 Grand Sport with 6-spd manual transmission and dry sump oil system have? I am aware of the main engine radiator, the auxillary engine oil cooler, the power steering fluid cooler and the rear differential cooler.
Do the manual cars also have a manual transmission oil cooler? If it does, what actually pumps the fluid as I wasn't aware that the manual transmission have a fluid pump? From looking at a parts diagram it looks like there are cooling lines which run from the right side of the radiator back to the manual trans, then there are lines that run from the manual trans back to a block shaped cooler/heat exchanger and then there are lines going from that to the differential.
Any other fluid coolers in the car?
Are the cooling systems in the manual transmission Grand Sports the same as in Z06's?
You've probably found this by now, but....
- Radiator (with heat exchanger for manual trans, same as auto trans radiator)
- Differential heat exchanger - mounted on rear diff, uses trans fluid as cooler, which is in-turn cooled by the radiator heat exchanger
- Oil cooler - air cooled
- Power steering cooler - air cooled
- A/C condenser
Received 4,746 Likes
- A/C condenser
This convertible is a dry sump
