New Pioneer receivers don’t fit in 2011 GS?
This has been a known issue with the Pioneer models with the removable face. Models like the 4100, 4200, and now 4400. There is a fix for it. It requires shaving or filing the Metra bezel a little. Here is a video showing the procedure.
https://www.youtube.com/watch?v=PGtcRy9SKnU
LiLi (04-01-2019)
Just curious, why do you guys prefer the Pioneer over say, Kenwood or Alpine? I'm just wondering what one to buy, and it seems like a lot of folks are getting the Pioneer. Is there anything that makes it a better choice?
I had the Sony XAV-AX1000 in my '93 C4 and hated it. There are a lot of folks that have liked it but I wasn't one of them - swapped it out with a Pioneer.. Now both the '93 and '12 have the Pioneer and so far so good - the main option I wanted for the '12 was wireless Apple CarPlay and the Alpine iLX was $200 more than the Pioneer AVH. I also bought the $12 mic for the auto-eq that's supposed to compensate for the cars acoustics. Maybe it's a placebo but I think it made the sound a lot better.
Received 1,637 Likes
The auto tuning with the optional mic, does help. It helps flatten out the EQ for the Pioneers making it easier to make your own adjustments to the EQ.
Pioneer Head unit
Hello everyone, just found something funny and was wondering what others have experienced regarding a new head unit upgrade. I have a 2011 Grand Sport and wanted to upgrade the head unit to a Pioneer AVH-2500NEX. I started my investigation by going on Crutchfield and noticed that their website was saying it wouldn’t fit. Then discussed it with there text support people and was told ALL the newer model Pioneer receivers were too deep for my vette. That the unit required 6.825” and my car was only 6.765”. So they told me to try a kenwood unit instead. I prefer the Pioneer unit and found it unusual that none of the Pioneer units would fit. So I went to 2 different installers and was told they would have no issues installing it as there was a Metra face plate and wire harness for everything for my car. I asked about the depth and they were dumb founded by my question. Both installers use Pioneer as there main product. So then I checked this forum for info and see that others have installed Pioneer units although not the same model. So just wondering if anyone has any input regarding newer model Pioneer unit installs with a depth issue during install?
Old Factory Nav
New Pioneer Head unit
Installed
It's true does not fit. I installed Pioneer Avic-8201Nex in my 2008 C6 AT LT3 Removed factory Nav. Had to do small modification to have the proper clearance. There's a mount about 1-1/2 square that has a locating pilot hole on the center of it. It's molded plastic as part of the dash. Since the Pioneer head unit does use it. I just cut it off with a small Dremel tool. After that no problem.
The following 2 users liked this post by CSixDude:
LiLi (04-01-2019),
OneBadLT123 (04-03-2019)
I did the steering wheel swap on my 05, so I now have steering wheel controls for mine, prior to doing that I had a small Pioneer remote control velcro'ed to the center console that I used, or I used the volume buttons on the unit itself.
Black stud lower center on old unit
Have steering wheel control for volume and unit has push button for volume + and - next to the map button
I miss a turn **** in my '93 since there are no wheel controls. I don't miss the turn **** in my '12 since I use the wheel control's 99% of the time.
Installed
Installed
picture of mine,
#33
I am in the market to replace my 2013 LT3 Coupe radio/nav.
Question1: Did either of you install the backup camera? If so, how does it look on the outside of the car and the video itself. Does it engage when you put the car in reverse? Or do you need to select the backup camera from the screen.
Question2: Did you lose any HUD features?
Question3: Are all your existing steering wheel controls working?
Question4: The description of the unit states that to use various Android auto features including Google Maps I would have to purchase and run an USB cable. Is this the same Auxiliary port that is in the center arm rest?
Question5: When you have Bluetooth on and you receive a text message does your radio switch from the radio to Bluetooth on the device leaving you to change back to the radio?
Sorry for all the questions.
Thanks guys!
Thanks guys!
#34
Thanks guys!
Thanks guys!
2- You only lose navigation through your HUD and or any radio station info. All the other things on the HUD still function normally.
3- With the correct interface/wiring harness you can retain steering wheel controls. They come preprogrammed, but the phone end and answer are programmed as mute/source. You can reprogram them but some have difficulty getting the end button programmed correctly.
4- I ran the USB cable that came with my head unit to the center console. I did not reuse the existing usb port, but removed it to run the cable into the center console.
5- The head unit handles the text/bluetooth features without any issue. No need to switch back to radio or source if you get a text message. All works pretty much seamlessly with your phone.
LiLi (04-02-2019)
#35
What is the purpose of the bottom being bowed out for the control panel?
#36
Thanks guys!
Thanks guys!
The HUD works the same but no longer displays turn info like the factory Nav did
Steering wheel controls are fully functional. I used "RP5Pro for all interface including Bose factory amp and OnStar
I have Two (2) USB ports installed in the glove box.
Text messages display on top of the screen. System will lower volume beep then return to the previous state fully automatic.
Rear Cam
Front Cam
Pac Audio Interface
XM
Bluetooth Mic
I also have HDMI cable to display "Mirror" my iPhone Internet,Youtube,Waze,App Radio,Google Maps. Anything on the phone.
LiLi (04-02-2019)
#37
marinablu67 (04-01-2019)
#38
THANK YOU!!! I just looked on line (Best Buy) and the 8201 is out of stock. ?? I am looking into having them do the install as it will be warrantied at any location. jeffs64 Is is necessary to mount the headunit microphone like you pictured or will my microphone work? Thank you for the pictures. This helps me a ton. I didn't even think about the HDMI for mirroring.
I am now on the hunt for the 8201. Soon as I get this purchased and installed I will post the before, after and outline any items that had to be purchased.
I am assuming this unit also has the parking break restriction on it for downloading data off a USB? I have a Pioneer 601ex in another car and just tried to put on a logo from a thumb drive and it will not let me download. Videos outline the parking break restriction. I believe there is another set of jump wires to install to get around this hassle.
Thanks Guys!!!
Thanks Guys!!!
#39
Cruising
Yo Vette Bros
Installed Pioneer AVIC-8200NEX in my 2013 Grand Sport. Sounds Grrreat! Cheers.
CorVetteJones (04-03-2019)
#40
Thanks Guys!!!
Thanks Guys!!!
LiLi (04-02-2019)
