Jack up C6 to change oil
#41
#43
Agreed, this is another great reason to do it yourself. In a normal, everyday car you don't care about, sure I can understand. Why pay someone to work on your baby? Best case scenario, its done the right way with care and you paid more than it would have been to do it yourself. Worst case, it was taken for a joy ride, improper handling, scratches to paint, messed up interior, wrong procedure, etc.
#45
Ok thanks, just saw someone say they simply turn their wheels to the right and jack up the the driver side up to get to the filter and plug. Haven't looked at the drain plug yet. Will probably be doing an oil change on both vehicles this weekend.
#48
Lifts
After paint and treaplate.
Lots of threads on here about lifts but i don't have enough height to have a 2 post or 4 post.A guy in my area sells these used very reasonabie.Before paint and treadplate.
In use with my 08.If anyone in the North Ga.area would be interested in one PM me and i can hook you up.American made 6000 pound hydrolic with reservoir and pump.
#50
I changed mine last friday. Why not buy a low profile jack from Summit? Ramps are not for me. I have NEVER had a use for ramps. Jack up the driver's side in the "puck" location, put jack stand under engine cross member material with a block of wood, lower the jack on the stand and keep the jack there as well. Drain and change the filter.
#51
#52
Seems like some of you drain your oil without having the car level. No concerns about getting the last of the old oil out?
I have no idea if this is a big deal or not but I always drain my oil with my cars level. Same with every dealer, small shop or oil change facility that I have ever seen.
#53
Received 1,137 Likes
Cuz the dirt slopes down from my barn floor, when my car is on the ramps as below, it is level.
HBsurfer (05-01-2019)
#54
#56
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
I used a KWIKLIFT for ten years for oil changes and cleaning under the vette,I used a creeper to slide under.!
#57
Well I read on the trusty forum, you should change your oil minimum once a year. It has been a year already. Oil was most likely good . I change it on my buick when the sensor tells me to. I read that the oil life monitoring by GM is legit.
#59
