Chirping noise
Subscribe
Apr 13, 2019 | 06:12 PM
Let me know what you think but a sound you hear in the video, thank you.
Reply 0
Apr 13, 2019 | 06:24 PM
My buddy's chirp was from misalignment of the belt system, alternator etec.
Reply 0
Apr 13, 2019 | 06:31 PM
After watching and listening to the vid it sounds like a kind of vacuum or exhaust manifold leak
Reply 0
Apr 13, 2019 | 06:33 PM
Start by eliminating all the belt and tensioner possibilities people will suggest, but I think you have a bad valve lifter causing the chirping noise.
Reply 0
Apr 13, 2019 | 06:57 PM
Quote: Start by eliminating all the belt and tensioner possibilities people will suggest, but I think you have a bad valve lifter causing the chirping noise.
I second extrapilot. Take both belts off. If the sound persists, it's not any of the accessories. If it goes away, you've just narrowed it way down.
It does sound like a lifter roller, though I would expect to see elevated iron in your oil analysis from cam lobe erosion. How long has this noise been going on?
Reply 0
Apr 14, 2019 | 01:48 AM
You can simply spray some water on the belt and if it stops chirping for a few seconds it's the belt system.
Reply 0
Apr 14, 2019 | 08:01 AM
Subscribing for follow-up info. Good luck OP. Please report back with any findings.
Reply 0
Apr 14, 2019 | 09:15 AM
My car had it for several years before I sold her - never had any issue - I pinned it down to the alternator (guestimate) but it never ended up failing me. Bottom line is that I would not worry about it IMHO.
Reply 0
Explore
Apr 14, 2019 | 09:34 AM
a loose spark plug can cause this - as well as a bad belt tension adjuster.
Reply 0
Apr 16, 2019 | 07:09 PM
Could be many items:
Belts (take them off one at a time and see if it disappears)
Harmonic balance (or belt) - Many vette enthusiasts swear by Gatorback belts
Pulleys / tensioners
Hope this helps
Reply 0
Apr 16, 2019 | 09:04 PM
Worst case, it could be a lifter that has failed. Its happened to me. If it is, don't run the engine. While its running its grinding on the cam. Heads have to come off to replace
Reply 0
Apr 17, 2019 | 06:05 AM
Quote: Worst case, it could be a lifter that has failed. Its happened to me. If it is, don't run the engine. While its running its grinding on the cam. Heads have to come off to replace
And the camshaft replaced even if it's slightly scored, at a minimum. Engine will have to be inspected for further damage if metal is found elsewhere, Good idea is to have the oil filter removed and cut open for inspection of the filtering pleats.
Reply 0
Apr 17, 2019 | 06:57 AM
It's too difficult to tell what the sound is with headers. They make the valve train so much louder and really obscure the chirp.
Reply 0
Subscribe
