magnuson supercharger air cleaner
Old 04-17-2019, 11:35 AM
candipogo
candipogo's Avatar
Default magnuson supercharger air cleaner
i just bought a 2007 coupe with a magnuson supercharger kit. the kit was sold thru callaway cars. at that time, you could not purchase directly thru magnuson. i am also trying to find out who the first owner was in hope of help. i have been doing some refresh under the hood and i need or would like to buy another air cleaner. K&N does not make the filter. and i can't get much info from magnuson. it's and oblong filter 20'' wide by 6'' deep on the inlet side. the inlet is 3-1/2''. the cold air unit which is a magnuson fits into the flange on the air cleaner and clamps on. i thought maybe some of you guys might have this type of set up on an ls-2. i know the stock air cleaner was a flat panel deal that fit into a shroud in front of or over radiator. the cold air kit apparently did away with that. i don't know if a Z06 had this type set up or not. any help is appreciated.
phil 901 550 1634
Old 04-17-2019, 08:25 PM
candipogo
candipogo's Avatar
intake flange is 3-3/4inch sorry for mix up.
phil
Quick Reply: magnuson supercharger air cleaner
