Replacing Brakes
170mph, WOW.
Supporting Vendor
St. Jude Donor '11,'13
For a high quality low dust performance street pad take a look at the Carbotech 1521 brake pads.100% non-corrosive dust will not harm your wheels, paint or rotors..Carbotech brake pads are 100% made in the USA and can be ordered online herehttp://ampdautosport.com/brake-pads/corvette/ or call me at 216-780-8825. The part numbers you need are front CT731 and rear CT732. Use promo code z28 at check out to receive your forum discount.
The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non-corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Received 2,061 Likes
Just for reference, I have no problem making a fairly hard (nowhere close to panic) shutdown in less than 1000 feet to make the first turnoff at the dragstrip after a 125+ mph pass. I'm using base JL9 rotors, custom drilled to look like J55's, and J55 rear calipers. Current pads are Oreilly's (brand unknown) at less than $50 per axle.
Could I get better pads? Absolutely. Do I normally drive in a manner that would require better pads? No. Will I buy better pads when I do my next brake job? Most likely.
In traffic, I tend to watch my mirror to slow at a rate that allows the car behind me as much time and space as possible to avoid a rear end collision, yet avoiding hitting the car in front during their panic stops.
There are very few cars that can stop quicker than the average C6. No matter what you drive, how you drive it is more important than the vehicle itself.
I've been as high as 180 mph and over 150 more times than I can count, but only knowing in advance of how much space for shutdown is available on the road ahead. As aerodynamic as the C6 is, you can still slow down fairly quickly to 130 without touching the brakes. High speed stops can be dangerous and kill rotors if used aggressively. It's why NHRA requires parachutes on cars that exceed 150 mph.
Cherokee Nation (04-23-2019)
Cherokee Nation (04-24-2019)
