CD Mech Error
Old May 4, 2019 | 05:15 PM
dcarter0001's Avatar
dcarter0001
Default CD Mech Error
while trying to eject a cd this error message displayed "CD Mech Error" Now nothing works. It will not play a cd or change cds or eject a cd. I have tried everything evem sticking a knife in the slot. Anyone have any suggestions?
Old May 4, 2019 | 05:22 PM
4SUMERZ's Avatar
4SUMERZ
That doesn't sound good at all. You can remove the unit from the vehicle, remove the top cover so you can get access to the CD unit. The CD may be stuck in the unit, etc. That is the only suggestion that I can come up with. I've had the top cover off to clean the CD laser lens, so CD access will also be available.
Old May 5, 2019 | 09:16 AM
dcarter0001
I was afraid of that. Is it hard to get the unit our?
Old May 5, 2019 | 09:39 AM
4SUMERZ's Avatar
4SUMERZ
Originally Posted by dcarter0001
I was afraid of that. Is it hard to get the unit out?
You have to remove the radio surround console ( PDF attached) then there are 4 screws to remove the unit from the dash. Unclip the connectors for the FM antenna, GPS antenna, mike input, XM input and the unit is freeded up. The top of the unit has 6 phillips screws holding it on.
Here is a you tube for removing the radio surround console
File Type: pdf
Old May 5, 2019 | 11:45 AM
Landru's Avatar
Landru
Before removing unit might consider battery disconnect trick to reboot computers.
Just might save a lot of work.
Can't hurt If not tried, already.
As always whenever C6 power's interrupted, re-indexing windows is required.
Old May 5, 2019 | 12:57 PM
dcarter0001
Thanks. I tried it but it didn't work. I think it is jammed by one of my discs I made with stick on labels
Even though I disconnected the battery, it did not completely power down the radio because I still have the presets and clock setting. Is there any way to completely power down the radio to hopefully reset the error code?
Old May 5, 2019 | 01:20 PM
Landru's Avatar
Landru
I think it is jammed by one of my discs I made with stick on labels.
Same thing's happened to me more than once.
Each time I was very fortunate to snag it w/ a hemostat.
Appears it must come out, opened & tag removed.
Good time to clean lense.
A strip of scotch tape over labels and it'll not happen, again.
Old May 5, 2019 | 03:45 PM
dcarter0001
I wish I could grab it. I think it's down inside the 6 disc unit somewhere.
Old May 7, 2019 | 11:33 AM
dcarter0001
Old May 7, 2019 | 02:19 PM
Landru's Avatar
Landru
Only way I can think of is remove unit requiring all connections, including power, to be disconnected.
IF it's still powered-up after disconnecting let me know.
We'll file a patent for a perpetual energy source.
Make enough $ to buy Lamborghinis, use C6s for anchors on our new yachts.
Kidding aside, unit needed to come out anyway for label removal. Right?
Old May 7, 2019 | 02:40 PM
Shelstin's Avatar
Shelstin
Or, just don't listen to CD's. I can't remember the last time I did that. If i want to listen to the same music over and over again, I will listen to Pandora!
Old May 7, 2019 | 02:46 PM
SPSandman's Avatar
SPSandman
That is a bummer!
Yeah I listen to all my music via my phone. Does the 6 disc changer have a USB connection, or was that added later on?
Old May 7, 2019 | 03:16 PM
dcarter0001
My 2005 has No USB, No Bluetooth. The CD is it.
HOWEVER, While driving to the store today, I pushed CD and it started working. I don't believe it,but everything works. I ejected the CD's and there were no stick on label CD's in the unit.. I don't know what was wrong and I don't know what fixed it .That bothers me but right now I am just happy./
To CD Mech Error
