2009 Corvette Speaker crackle
Cruising
Am I the only one who has a speaker crackle in the passenger side door of the corvette? Has anyone had the same problem and any tips on fixing it?
JenniferChgo (06-08-2019)
Received 1,636 Likes
Sounds like the door speaker is blown.
If it the large speaker more than likely the cone has separated from the voice coil. Might not be completely off but water runs in the door and across the back of the speaker causing the delamination. I took both mine out of my 2013 that is garages and has seen limited rain. Water from frequent washing does it. I cleaned the area of rust and applied shoe goo and let it dry overnight no more cackle or buzzing when bass hits and I have cranked it up to test no issues.
The following 2 users liked this post by ontime:
chrisharek (05-14-2019),
I just upgraded both the speakers in the door with Rockford Fosgate components and the speakers behind the seats with Kickers. www.crutchfield.com is where I order everything. They are really good about wiring harnasses and such.
Also, taking off the door panels is not the easiest to do - especially alone. I'd suggest having someone help you while you lay under to line up the pins and such. Good youtube videos out there on how to remove too. Oh, and each door is different due to the handles. There are 2 torx screws in each door - on the passenger, one is hidden behind the door release button!
Good luck!
Good luck!
The following 2 users liked this post by chrisharek:
JenniferChgo (06-08-2019),
lazerlemonta (05-14-2019)
My problem is that occasionally the right door speaker just goes "out" (no sound), then, after a while, it comes back on. Still have sound from left side. I've assumed must be a loose wire, either in door or on back of radio. But could this water problem you refer to be my problem? Don't have the crackle that OP refers to. Or, are the speakers just wearing out as others have mentioned.
