clock
Old May 23, 2019 | 06:08 PM
paldogy's Avatar
paldogy
Default clock
My clock went blank on the navigation screen. Any solutions?
Old May 23, 2019 | 07:52 PM
cmonkey713's Avatar
cmonkey713
Lots of posts on this. Did you disconnect the battery? If so what was the date?
Batteries disconnected after mid November 2018 until sometime in April 2019 had this problem. Some of the clocks reappeared about mid April but not all. Some seem to think it has something to do with the refreshing of a GPS satellite software but nobody really knows. No known fix at this time.
Old May 23, 2019 | 08:23 PM
paldogy's Avatar
paldogy
Thanks, I did put a new battery in about a week or less ago. That seems to be a snafu
Old May 23, 2019 | 11:01 PM
Eritosthenes's Avatar
Eritosthenes
There's a sticky thread in C6 Tech/Performance you'll want to follow. There was a Tech Bulletin issued in February, but it doesn't offer much. The truth is GM and DENSO fumbled the ball in 2011 when the Air Force announced changes to GPS broadcast message header formats. Think of this as a Y2K-like problem. The firmware in C6 and Cadillac head units was never updated to comply with the change. As a result, they can't properly decode those headers and extract the data needed to compute time correctly. GM is "working on a solution". If you believe that, I have a bridge I want to talk to you about.
Old May 24, 2019 | 07:26 AM
paldogy's Avatar
paldogy
I read the sticky blurb and looked at about 40 posts. It seems hopeless. Thanks for the help.
Old May 24, 2019 | 11:35 AM
Landru's Avatar
Landru
Maybe not.
A few members reported non-functioning clocks start working.
Claim they'd done nothing, got in one day & it worked.
Whatever happened only GM knows, and they're not really talking.
Safe to say it's software related.
Give it some time, might just rectify itself as it did w/ others.
Old May 24, 2019 | 06:02 PM
cmonkey713's Avatar
cmonkey713
Originally Posted by Landru
Maybe not.
Mine came back on April 6 at 10:45 AM while driving. It had been off since I disconnected the battery for seat cover install in November 2018 .
Old May 27, 2019 | 12:45 AM
vett_guy's Avatar
vett_guy
Mine went out in December, after a battery change, and came back on the first week in April. No big deal to me because I'm going to replace the head unit soon anyway. Good luck with your clock, it may just pop back on one day!
Old Jun 1, 2019 | 11:04 AM
VETFEVER's Avatar
VETFEVER
My battery is aging a bit and I am set to replace it. Does anyone know if an ailing battery contributes to this issue??
vetfever
Old Jun 1, 2019 | 12:18 PM
Landru's Avatar
Landru
A weak/dying battery doesn't 'contribute' to loss of clock last I read the technical details of this, it's software related, some kind of change w/ GPS et al.
If you've a weak battery replace it before you get stranded, hell w/ the clock.
Had exhaust work done on an '08 Z06 Jan '19, battery disconnected.
Clock's still there so this happens w/ some, but not all.
To complicate matters some who lost their clock reported at some point regaining it.
To clock
