C6 Shifter Issues
I have had the brake switch changed about 2 months ago and had cable replaced by dealer about 1 1/2 years ago. Not a daily driver use only about 2500 miles a year. I think I have read about this issue before and any help would be appreciated
Most of us with the 6 speed auto shifters simply tie back the locking Pawl, or at least tie a wire to it so it can be released if it doesn't happen electrically.
I've attached a PDF to show you what I'm talking about.
BTW- if you bring this issue up to a dealer, they will happily replace the whole shiter assembly, which in time will have the same issue.
This is the thread about the switch (a great read and info)
https://www.corvetteforum.com/forums...use-found.html
