Replace Hoses?
Old Jul 7, 2019 | 05:12 PM
thehueg's Avatar
thehueg
Default Replace Hoses?
2008 C6 Coupe base model. Car has 55,000 miles and at this point no leaks or bulging hoses. I live in New Braunfels, TX so it is rather hot. Is there a proscribed time frame for changing hoses or is 55,000 miles still early? Coolant flush 15,000 miles ago by the way.
Old Jul 7, 2019 | 05:40 PM
Rocketmanwpb's Avatar
Rocketmanwpb
I have an 08 I bought new with 139K currently with original hoses. I change the coolant per the recommended time/mileage. One of my friends went 150K with his C5 and he only changed the hoses when he changed the water pump. I just returned from a weekend trip with 80mph highway speeds at 90 degree temps with no problem.
Old Jul 7, 2019 | 05:55 PM
ls1121's Avatar
ls1121
St. Jude Donor '14-'15
hoses are cheap, if you feel it's time then it's time. I replace things just because I feel it's time and many of the cheap parts I do often.
Old Jul 7, 2019 | 07:03 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
I have 05 with 72,000 miles, and my bottom radiator hose was replaced cause it was leaking!
Old Jul 7, 2019 | 07:44 PM
cmonkey713's Avatar
cmonkey713
Age will effect hose life far mare than miles. On your '08 I would go ahead and replace the hoses not because they are bad but the age of the hoses. I like to decide when to replace parts rather than the parts failing at the worst possible time.
Old Jul 8, 2019 | 12:22 AM
HOXXOH's Avatar
HOXXOH
These cars don't have the same type hoses your grandfathers Studebaker did. They last a lot longer. 157K on my '08 with original hoses, belts, plug wires, etc in hotter'n hell AZ.
To Replace Hoses?
