Weird Question
Old Jul 25, 2019 | 09:48 PM
rlgood's Avatar
rlgood
Default Weird Question
I recently purchased a 2011 Grand Sport M6, here's my question. I have a long driveway, it's gravel and I travel slowly in first gear right about 1000 rpms and it feels like the brakes keep applying and releasing repeatedly, anyone experience anything like this before? 66k miles, no lights on, previous owner just put new calipers, rotors, pads, tires and wheels. I don't notice anything abnormal on the road. Thoughts?
Old Jul 25, 2019 | 10:17 PM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
Traction control? Turn it off and see.
Old Jul 25, 2019 | 10:29 PM
rlgood's Avatar
rlgood
Forgot to say that in my post, have turned traction control off, and tried competition mode, no difference. Thanks
buckmeister2's Avatar
buckmeister2
I'm thinking traction control, or possibly ABS if you have light pressure on the brakes when it occurs. If it never happens on smooth pavement. I can't think there is anything wrong with the vehicle. Maybe someone else has a better idea.
Old Jul 25, 2019 | 10:36 PM
rlgood's Avatar
rlgood
Foot not on brake, I was thinking the same lines ABS or Trac control, but no lights at all, odd. Haven't tried to see if it does it on pavement. My drive is actually fine asphalt millings, I wondered if the traction control on these are over sensitive and it thinks there's tire slippage.
Old Jul 26, 2019 | 01:11 AM
Iceaxe's Avatar
Iceaxe
Turn traction control and active handling off completely and see what happens. Press and hold the button for 5 seconds.
Old Jul 26, 2019 | 07:07 AM
rlgood's Avatar
rlgood
Already did that, no change.
Old Jul 26, 2019 | 09:34 AM
Vettereturned's Avatar
Vettereturned
Try taking it out of gear and see it you feel it when coasting - that may help pin point brakes or drive train.
Old Jul 26, 2019 | 09:44 AM
madsonp's Avatar
madsonp
I too have a gravel driveway, and I don't have this issue in my 05.
Old Jul 26, 2019 | 09:59 AM
cgladish's Avatar
cgladish
also try a different a driving surface, other then your driveway but, similar in make-up.
see if you get the same issue. if it doesn't happen on smooth roadways, but only gravely ones, I wouldn't worry about.
that it unless you plan on doing the Baja 1000(?).
Old Jul 26, 2019 | 10:07 AM
CJ Willys's Avatar
CJ Willys
Does same thing happen on asphalt or concrete?
Old Jul 26, 2019 | 09:54 PM
rlgood's Avatar
rlgood
Played around a little today, does it on asphalt as well, also shoved the clutch in going down my drive and it seemed to quit, of course I was going slow and it slowed fairly quick but didn't feel like anything was grabbing like normal.
Old Jul 26, 2019 | 10:24 PM
Patsgarage's Avatar
Patsgarage
Maybe try 2nd gear and see if anything changes ? The way these cars are geared you can lug 2nd ~10 mph.
Old Jul 27, 2019 | 08:56 AM
rlgood's Avatar
rlgood
Does it in second as well.
Old Jul 27, 2019 | 11:08 PM
Patsgarage's Avatar
Patsgarage
Huh, well keep us updated if you find what it is.
Old Jul 28, 2019 | 01:04 AM
ttx350z's Avatar
ttx350z
Is the car cammed and it’s just surging?
Old Jul 28, 2019 | 09:38 AM
rlgood's Avatar
rlgood
Engine is stock.
To Weird Question
Old Jul 28, 2019 | 09:40 PM
Jstan2014's Avatar
Jstan2014
Old Jul 28, 2019 | 10:00 PM
joliett's Avatar
joliett
I think it's the engine surging (and it's bad for the car btw.) To prevent this, ...feather the clutch.
Old Jul 29, 2019 | 12:12 AM
rlgood's Avatar
rlgood
Not the engine surging, thanks.
