throttle position sensor
Old Sep 17, 2019 | 09:13 AM
vt65's Avatar
vt65
Default throttle position sensor
my '08 has thrown a code, looks like the tps and it won't reset, has anyone had a similar problem? Yesterday she just quit at the end of my driveway, everything went dead ... waited for a few seconds and it restarted and showed low engine power then quit again .... got it restarted and it ran fine except the throttle response seems to have quite a lag ... any idea's? Kinda afraid to drive it very far, nobody here in the area works on late model Vets including our GM garage to my knowledge so not sure what to do next..
Old Sep 17, 2019 | 04:10 PM
jamieo's Avatar
jamieo
From all that I have read the TPS is part of the throttle body and not repairable.Most have had to replace the throttle body.Not a cheap part either.Someone will correct me if I'm wrong.
Old Sep 18, 2019 | 08:40 AM
vt65's Avatar
vt65
thanks jamieo, update: ... found the problem code 0121 throttle pedal position sensor, have to replace the whole pedal assembly, here is a tutorial: https://www.corvetteforum.com/forums...on-sensor.html
To throttle position sensor
