Noise
Old Oct 7, 2019 | 11:13 AM
Pronnie's Avatar
Pronnie
Default Noise
Good morning,
I have been having a issue with a knocking noise by my drivers seat it feels like it’s under seat and whatever it is it’s draining the battery, help.
The seat is not working anymore
Old Oct 7, 2019 | 11:18 AM
BadgeZ28's Avatar
BadgeZ28
Have you tied playing with the seat position controls to see if the noise changes with their activation? The only other thing I can think of in that vicinity would be the fuel pump.
Old Oct 7, 2019 | 11:25 AM
Pronnie's Avatar
Pronnie
Default Noise
Yes I have and noise is still there and I will get the fuel pump checked out, will let you know what I find out and thank you.
Old Oct 7, 2019 | 11:32 AM
BadgeZ28's Avatar
BadgeZ28
You might try disconnecting the wire terminal for the seat controls first. It is a multi pin connector under the seat. I am guessing you will need to remove the four bolts holding the seat down and tip it to get to the connector. Good luck
Old Oct 8, 2019 | 09:29 AM
Landru's Avatar
Landru
This thread provides some insight to non-working seats: https://www.corvetteforum.com/forums...e-forward.html
To Noise
