2007 automatic trans
Old Oct 11, 2019 | 07:53 PM
Gary2007's Avatar
Gary2007
Default 2007 automatic trans
2007 base model z51 9000 mi automatic do i neen to change filter or just spill and fill
Old Oct 11, 2019 | 08:25 PM
Corvette_Ed's Avatar
Corvette_Ed
Any time you change the fluid in an auto trans you need to change the filter as well. It's no different than when you change your oil.
Old Oct 11, 2019 | 08:55 PM
Bruze's Avatar
Bruze
I've never done it on these cars, but I recall a pretty bizarre and complex procedure for it. If (my old) memory serves, I believe HOXXOH has outlined it in the past. Do a search with his name and maybe "tranny fluid change," or something similar.
Old Oct 12, 2019 | 01:04 PM
Gary2007's Avatar
Gary2007
Default Need all the help I can get
I don't know of anybody I can trust in Illinois to do it right anybody know who I can get established with retired willing to drive any where in state for anything this car might need thanks I.
Love this car would like to find one place that could do it all just can't trust dealerships.
Old Oct 12, 2019 | 02:05 PM
enventr's Avatar
enventr
Try to look up Corvette specialists in your area. You can possibly get in touch with a corvette club and ask them who they would use. Good luck
Old Oct 12, 2019 | 05:07 PM
cmonkey713's Avatar
cmonkey713
If the car is a daily driver or has low miles like 5K per year no need to change the fluid unless you track the car. I have drained the fluid on a 2008 C-6 with 60K miles and the fluid looked like new.
Old Oct 12, 2019 | 08:08 PM
Mike Green9's Avatar
Mike Green9
Check these links out to change tranny fluid/filter. I will be doing mine ('08 with 34,000 miles) in about a month. The first one is from HOXXOH and convinced me to do the job:
https://www.corvetteforum.com/forums...tructions.html
https://www.corvetteforum.com/forums...uid-level.html
Videos:
https://www.google.ca/search?source=...-l_Qbl8bXgCg28
Hope these links help.
M...
Old Oct 13, 2019 | 11:11 AM
HOXXOH's Avatar
HOXXOH
With only 9000 miles on the car, a transmission fluid change is not only not needed, but stands the chance of being subjected to errors of the process. The system is sealed with the exception of one tiny air vent, so there is no external source of contamination. Unless those miles were primarily during high performance events, your first fluid change should not happen until 50K miles if you drive in "severe" conditions or 100K in "normal" service. See your owner's manual for definitions and maintenance intervals.
Old Oct 13, 2019 | 08:14 PM
Mad*Max's Avatar
Mad*Max
I am in the minority but I would say not to change anything in the transmission - I no longer touch my transmissions after suffering failures subsequent to changing the fluid. My 07 was sold with 85k miles and 12 years with no issues and no flush.
Old Oct 14, 2019 | 12:46 PM
Mike Green9
Okay I have been convinced to leave my tranny alone at 34,000 miles (easy driving, but always use the paddles). At 2,000 miles/year, it will take me 33 years to hit 100K miles. Sadly at 71, that will likely not ever happen.
Once again, this forum rocks.
Thanks,
M...
To 2007 automatic trans
