When to shift
Old Nov 2, 2019 | 09:25 PM
Patsgarage's Avatar
Patsgarage
Originally Posted by jjfabs
I came from a lifetime of Jeep Cherokee's, Chevy wagons etc. My father had a '64 Buick Wildcat that was pretty quick. I drove a friends Z28 and Datsun 260Z, fast cars but nothing like my C6.
I really was just being curious about shifting at what rpm's. I doubt I will ever run through the gears at red line. Does that get me kicked out of the Corvette family now?.
You owe it to yourself (and the car) to do it at least once. I still laugh like a little kid when I dump it into 3rd @~60mph and floor it.
Old Nov 2, 2019 | 09:29 PM
ruxvette's Avatar
ruxvette
2016 C6 of Year Finalist
Originally Posted by 919cw313
I haven't seen a reason to refute that yet.
Lighten up, Mr Earnhardt, he said he knows how to stomp on it.
Old Nov 2, 2019 | 09:32 PM
jjfabs's Avatar
jjfabs
Sorry, my humor is very dry and my answers are full of snark, yet always based on facts.
Did you watch the video I posted?
Have you tried your 4500 rpm theory out and compared it to running up to 6500? Even the butt dyno will tell you the answer.
Mr. “Hence” knows his stuff when it comes to C6 repair, but he’s wrong on when to shift one.
Running on the expressway at 100 isn’t exactly extreme. Some people call that commuting. (**** I did it again, I can’t help myself)
Okay, since you had no real facts your answer was based on your need to insult.
I did watch the video.
I have not done a comparison between shifting at 4500 rpm or 6500 rpm.
Running at 100 where I live gives you a one way ticket to the pokey and probably the loss of insurance.
Read post #20
Old Nov 2, 2019 | 09:37 PM
ruxvette's Avatar
ruxvette
Originally Posted by Patsgarage
...the party was over by 4500 rpm max...
348/409 motors were good for more than that.
Old Nov 2, 2019 | 11:18 PM
LMB-Z's Avatar
LMB-Z
I think the key here is...."as fast as possible"...from 0-140. Not just simply achieving 140, but getting there as fast as possible. My guess would be near redline. But if you just want to get to 140, pick a straight rode, preferably in Mexico somewhere, the right time of day where there is less traffic, and just go for it. You will be surprised how fast 140 comes up. I can get 140 easily in 4th gear, and not getting close to redline in each gear...probably in the 15 or 20 second range, or less ( I've never timed it, but its quick)
Old Nov 3, 2019 | 08:21 AM
jjfabs's Avatar
jjfabs
Yes, I wanted to know what rpm I should get to in each gear to get to 140 as fast as possible. You must have plenty of long flat roads in Texas to do this. I was recently in eastern Colorado but the wife was with me, she would have been screaming the whole time.
Old Nov 3, 2019 | 08:25 AM
juanvaldez's Avatar
juanvaldez
Ought to be able to hit 140 in around 3 blocks.
Old Nov 3, 2019 | 12:22 PM
Spaceme1117's Avatar
Spaceme1117
I am not a speed demon, I don't often drive hard off the line and rarely drive over 90. I am just wondering if I wanted to go 0 to 140 as fast as possible at what rpm would I shift at for each gear?
Do you racers out there get near red line for each gear? Curious to see what you guys think.
You want to shift at the RPM that max HP is reached. Typically this is at or near redline but can change depending on if you have a cam, etc.
Old Nov 3, 2019 | 01:48 PM
HOXXOH's Avatar
HOXXOH
0 to 140 and back to 0 is easy within a mile in a stock C6. To be safe, have a clear visual for 2 miles ahead with no side roads, houses, or blind spots.
To do it in the shortest time, not only do you need to shift at or around 6500, but more importantly, how to launch in first gear from a dead stop. Lots of races are won or lost in the first 100 feet. If your 0 - 60 time is more than 5 seconds, you need more practice.
Old Nov 3, 2019 | 02:13 PM
Iceaxe's Avatar
Iceaxe
I live in Utah where long stretches of highway to practice are not an issue... this is I-80 just over the boarder into Mexico... LOL...
Old Nov 3, 2019 | 02:19 PM
TorchRedFred's Avatar
TorchRedFred
The easy and best answer is to change gears at or near redline. Guys are talking about rpm's and the motors horsepower, but are not taking gearing into consideration. A lower gear will provide an advantage when accelerating. So unless there is an extreme drop off in power or traction issues, you want to remain in the lower gear as long as possible, which in most cases is redline.
Old Nov 3, 2019 | 02:25 PM
HOXXOH's Avatar
HOXXOH
I don't remember that particular stretch, but since the last time I traveled there, I was running about 150 headed East from Wendover and may have blinked.
Old Nov 3, 2019 | 03:08 PM
  #33
Mfr's Avatar
Mfr
3rd Gear
Default Power curves
Differnt gears will give you power at differnt rpms. If you are really. Interested you can get a dyno and they can suggest the correct ct rpm to shift at.
Old Nov 3, 2019 | 03:11 PM
  #34
919cw313's Avatar
919cw313
2018 C6 of Year Finalist
Originally Posted by Mfr
...you can get a dyno and they can suggest the correct ct rpm to shift at.
(Which will always be redline.)
Old Nov 3, 2019 | 03:29 PM
  #35
Iceaxe's Avatar
Iceaxe
That particular stretch is nearly 50 miles long without a kink or dip... the other day I was talking to a guy and mentioned when your car hits the speed limiter it feels just like you ran into a wall... he asked how do you know that... LOL...
Old Nov 3, 2019 | 05:11 PM
  #36
73DBG's Avatar
73DBG
Yikes.
I think OP needs a WOT Box and to experience the glory of no lift shifts at redline(ish).......🤔
and I always enjoy your dry sense of humor and snarky(ness)
Old Nov 3, 2019 | 05:37 PM
  #37
juanvaldez's Avatar
juanvaldez
You want to shift after maximum torque available through transmission, i.e., torque in 2nd exceeds torque in 1st. Torque in 2nd will never/rarely exceed torque in 1st before redline in 1st. Same for 2nd. After 2nd gear it gets fuzzy. To figure this mess out you will need the torque curve of your engine and speed vs rpm in each gear plus the gear ratios of your transmission. Look at the torque at redline in 1st, multiply that by 1st gear ratio. Now look at the rpm you will be turning in 2nd when you shift at redline. You will find that the torque at that rpm multiplied by the 2nd gear ration is less than what you were getting in 1st.
For maximum acceleration you are looking for max torque to rear wheels.
To When to shift
Old Nov 3, 2019 | 06:45 PM
  #38
73DBG's Avatar
73DBG
Sometimes not shifting helps lol like if you can’t hook 2nd gear from a 40/50 roll
it is nice being able to do 60-135 in 3rd gear though
But 2nd to 3rd would be faster
Old Nov 3, 2019 | 07:48 PM
  #39
Patsgarage's Avatar
Patsgarage
I have to admit that I never drove one of them. I will say that I could wind out my 326 Pontiac (punched out to ~340) to ~5,500.
Old Nov 4, 2019 | 04:50 PM
  #40
Chiselchst's Avatar
Chiselchst
The good 'ole days...I used to run a Pontiac 428 in to my '64 GTO. It went flat dead at 5,000 RPM's, but had a lot of mid range torque...
