My driverside interior door switch sometimes works, the window indexes but door sometimes does not open.
the exterior switch works fine.
purchased new interior switch, installed and the switch still works spiradically. No improvement
So i am now opening my door with the emergency latch.
What do you think is the issue?
Had the same issues. Replaced the outside pads and fixed everything. You can test by swapping out the pads from driver to passenger side to see if it fixes it.
MF's probably correct.
However when removing door pad make damned sure to secure wires once loose.
Tape 'em to side, some members wound wires around a pencil, anything to prevent wire falling into door.
If wire falls into door a good deal of aggravation's required getting it out.
