Swapping Batteries
Old Nov 18, 2019 | 11:27 AM
Gunfighter1950's Avatar
Gunfighter1950
Default Swapping Batteries
Car has an AC Delco battery that is to tall and will not allow me to access the cabin air filter without removing the battery. Going back with an Optima Red Top model 35 which has a smaller case. When I disconnect the old battery will I loose anything? If so any way to prevent this? Car is an 08.
Old Nov 18, 2019 | 11:40 AM
Red06Vette's Avatar
Red06Vette
If you have factory GPS and have not done the update, see post #1447 of the following,
https://www.corvetteforum.com/forums...isconnect.html
otherwise you will only have to re-index your windows, info is in the owners manual.
Old Nov 18, 2019 | 11:41 AM
2008 Corvette's Avatar
2008 Corvette
2020 C6 of the Year Finalist - Modified
Default Battery
You will lose your clock and have to index your windows, however there is a fix for that. Check the forum. I also have an Optima red 35 and can change cabin filter with battery installed.
Old Nov 18, 2019 | 10:33 PM
cmonkey713's Avatar
cmonkey713
You indicate there is a fix for the clock issue, can you share the fix or web site with us?
Old Nov 18, 2019 | 10:44 PM
2008 Corvette
Default C6 Clock
. There is a sticky at the top of C6 Tech/Performance page.
Old Nov 18, 2019 | 10:49 PM
Trebor's Avatar
Trebor
My '06 will need a battery upgrade in the spring. I plan on plugging my battery maintainer into the cigarette lighter to supply the systems power , then removing my battery for replacement. That should keep the clock and navigation systems alive.
Old Nov 18, 2019 | 11:03 PM
2008 Corvette
Might work and might not.
Old Nov 19, 2019 | 01:21 PM
AZ_DSOM's Avatar
AZ_DSOM
Active Streak: 90 Days
I had to disconnect my battery last week to do the "F1Mod" and upgrade my paddle shifters; when I reconnected my battery the clock was gone. I did the "fix" listed on the Tech Forum and was able to get it back.
Old Nov 19, 2019 | 04:31 PM
Mike Green9's Avatar
Mike Green9
Battery Tender plugged into the cigarette lighter kept everything alive on my Cadillac STS. IMHO it will work on the vette.
M...
Old Nov 19, 2019 | 07:50 PM
2008 Corvette
M...
I wouldn’t do that if you are removing steering wheel or seats with side airbags. Everything else worth a try.
Old Nov 20, 2019 | 04:42 PM
Gunfighter1950
would you get the same thing if you connected the battery terminal wires to a battery tender instead of the cigarette lighter
Old Nov 20, 2019 | 05:31 PM
SPSandman's Avatar
SPSandman
I had to change my battery last week and I didn't lose anything. Battery was out of the car for about an hour while I went to get the new one. Didn't lose my clock and didn't have to reindex my windows, which surprised me.
Old Nov 20, 2019 | 05:56 PM
2008 Corvette
. This issue doesn’t not effect 2012 Corvette. Window indexing you we’re lucky. Only effects 2005 - 2009 for clock
Old Nov 20, 2019 | 06:28 PM
Mike Green9
Gunfighter1950 asked: "would you get the same thing if you connected the battery terminal wires to a battery tender instead of the cigarette lighter?"
YES.
M...
To Swapping Batteries
