Window problem
Old Dec 22, 2019 | 06:47 PM
RomanM14's Avatar
RomanM14
1st Gear
Default Window problem
Hello, I have a 2008 corvette base and I am having a problem with my windows, my drivers side window will open and close but the passenger side window won’t go down or up and the door won’t open from the inside or the outside but the door does un latch with the lever inside but since the window won’t move the door can’t clear and open all the way, I tried disconnecting the battery and nothing worked, I was wondering if anyone has some idea of what’s happening.
Old Dec 22, 2019 | 08:32 PM
2008 Corvette's Avatar
2008 Corvette
2020 C6 of the Year Finalist - Modified
. Index both windows. Instructions in the Manual.
Old Dec 22, 2019 | 08:56 PM
farmington's Avatar
farmington
Check the wiring inside of the door. With two things dead it sounds like a power issue.
Old Dec 22, 2019 | 09:01 PM
2008 Corvette
. Read it again. Where does it say that two things are dead ?
Old Dec 22, 2019 | 09:15 PM
farmington's Avatar
farmington
Door won’t open (electric). Window won’t go up or down (electric). Hmmm.
Old Dec 22, 2019 | 09:45 PM
2008 Corvette
index window and door will open. If he can’t get the door open how does he check the wiring ?
Old Dec 22, 2019 | 09:55 PM
Vette_DD's Avatar
Vette_DD
Resetting the window indexing
With the engine running and the window down, close the car door. Raise the window and hold the up switch an extra 3 seconds. Release. Without lowering the window, hold the up switch again for 3 seconds. Release. Done. Don't forget the other window.
This will need to be done to both windows every time the car battery is disconnected, then reconnected, or when a new battery is installed in the car.
Old Dec 22, 2019 | 10:06 PM
2008 Corvette
Thank You.
Old Dec 23, 2019 | 02:01 AM
Cherokee Nation's Avatar
Cherokee Nation
I never read the manual on indexing, the service manager at the dealer where i got my 08 new showed me the way to do it...1-put in ACC mode with door closed roll window up and hold for three seconds then roll window down and hold for three seconds..and i have done it that way at least 50 times and it works.....There is always more then one way do do something.
Old Dec 23, 2019 | 09:47 AM
z06clif's Avatar
z06clif
Always a sign of a weak or mal fu ctioning battery....or electrical gremlins of some kind. Fixing is simple finding the cause is a little bit harder
Clif
Old Dec 23, 2019 | 11:12 AM
Vette_DD's Avatar
Vette_DD
If you've done it at least 50 times, you may have a problem.
The first paragraph of my post was just a quote of information in the owner's manual.
Old Dec 23, 2019 | 03:40 PM
Cherokee Nation
Yes I understand about manuals....It might not be 50 times ,but damn close....I don't have a problem it's the damn car....I think it just might catch on fire one of these days.....
Old Dec 24, 2019 | 12:20 AM
joliett's Avatar
joliett
Weak battery...read on...
Just happened to me a month ago...Window wouldnt get away from itself...so I re-indexed windows...fixed the issue... ha.
...then 10 minutes later, 2 miles away from home, in town...the car wouldnt start...it cranked about 5 seconds and the engine sounded like the end of the world , including the dash lighting up like Christmas...while I kept telling myself...it's the battery, it's the battery.
Think...think...Ahhh...Maybe NAPA would deliver the battery. My local NAPA manager...who always calls me by name for years.....actually came to me and delivered the new battery .
Then the car started up smooth as silk, but the voltmeter wouldnt move...oh no...no...oh well...I can change out the alternator...but then I realized I was looking at the gas gauge...phew!
The next day, I removed the battery connectors and sanded them....dont forget that!
To Window problem
