Idiot needs help
Old Feb 12, 2020 | 07:38 PM
72greg's Avatar
72greg
Default Idiot needs help
I'm trying to find the bleeder valve for the clutch hydraulic fluid on my 06 manual Coupe.
Per the service manual, and after doing 100 burpees getting under the car and getting up to read the manual,...
I have a question,....
I removed the 300 8mm bolts holding up the drive line closeout panel.
Where is the bleeder screw on the clutch actuator cylinder?
I'm completely baffled.
Thanks,
Village Idiot
Old Feb 12, 2020 | 08:27 PM
jamieo's Avatar
jamieo
https://www.corvetteforum.com/how-to...-system-368192
Old Feb 12, 2020 | 09:31 PM
torquetube's Avatar
torquetube
Thanks,
Village Idiot
See post #15:
https://www.corvetteforum.com/forums...eed-screw.html
The thread subject is installation of a remote bleeder, which I highly recommend, but you could perform a conventional bleed the same way.
Some people claim to have accessed the bleeder from the top. It is (just) visible from the engine compartment, so I believe them.
Old Feb 13, 2020 | 10:18 AM
Fly N Low's Avatar
Fly N Low
Thanks,
Village Idiot
You will see the hydraulic hose coming down from the clutch master cylinder and entering the torque tube right behind the bell housing. It enters on the top side so it is very hard to get to. I wouldn’t attempt bleedIng it unless u have no choice. Also if you ever have the torque tube out definitely install the remote bleeder hose to resolve this problem.
Old Feb 13, 2020 | 12:37 PM
72greg's Avatar
72greg
I found it. Ridiculously stupid design.
Old Feb 13, 2020 | 01:34 PM
John Harry's Avatar
John Harry
St. Jude Donor '10-'11-'12-'13-'14
Yep. At the time GM didn't plan on any regular maintenance for the clutch fluid. The owner's manual said nothing. It was only later that they realized it should be replaced every couple of years, just like the brake fluid in the braking system.
To Idiot needs help
