Ignition button
Old Feb 13, 2020 | 04:29 AM
Robert Mcamis's Avatar
Robert Mcamis
6th Gear
Default Ignition button
Good evening had recent work done on my base model 6 convertible now when i shut my car off my ignition button stays on for 15 to 20 minutes thank God cant get with out the keyfob it never used to do that any suggestions please help thank you Robert not that the car tries to start its that the light stays on
Old Feb 13, 2020 | 09:20 AM
Reckedhim's Avatar
Reckedhim
My suggestion would be to use punctuation to actually make that readable.
Old Feb 13, 2020 | 09:25 AM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
It would help if you told us what work was done to the car. When you say the lights stay on for 15-20 minutes, which lights are you referring to, interior or exterior?
I hope I got all mu punctuation correct.
Old Feb 13, 2020 | 07:26 PM
Robert Mcamis
6th Gear
Yes but your spelling needs as much help as my punctuation nevermind ill go elsewhere
Old Feb 13, 2020 | 07:52 PM
owc6's Avatar
owc6
There are many knowledgeable folks on here, but like any other site, a thick skin is useful so you can get the help you need. That said, your post was a bit difficult to discern exactly what the problem is.
My take on it was: You had some undetermined work on your car, and now the car will stay powered on (as if in ACC) for 15-20 minutes, but you still can't get out w/o using the fob to unlock the car.
Is that correct?
To Ignition button
