Vette needs help.
Old Feb 25, 2020 | 08:50 PM
Randall Musick's Avatar
Randall Musick
Cruising
Default Vette needs help.
I have a 2010 Base Model C6 - I'll can be driving down the road everything shuts down radio goes off and AC shuts off and all my lights on the dash goes off and on all the service messages comes on and off but the car keeps running.
I've checked all plugs to the CPU I've replaced the Alternator and replaced the Battery and I still have the problem please help.
I've even checked the kick plate on the passenger floor board.
File Type: avi
Old Feb 26, 2020 | 12:39 PM
R_W's Avatar
R_W
Do you have anything plugged into your OBD2 port under the steering wheel?
Old Feb 26, 2020 | 01:05 PM
C6fromtheD's Avatar
C6fromtheD
Ground!
Old Feb 26, 2020 | 02:51 PM
Randall Musick
Cruising
I just wish I knew where to begin looking for it. Any Ideas...
Old Feb 26, 2020 | 02:53 PM
Randall Musick
Cruising
I do what would I look for?
Old Feb 26, 2020 | 03:04 PM
C6fromtheD's Avatar
C6fromtheD
You have few under the hood wheee the battery and fuse box is.
few on each side of the strut.
main plug under the passenger side footwell
Old Feb 26, 2020 | 04:21 PM
EviLS7's Avatar
EviLS7
I remember when I replaced my alternator we forgot to torque down the ground bolt on the block. My car shut off 3 times driving and eventually found out it was that and torqued it down with no more issues.
Old Feb 26, 2020 | 04:24 PM
Randall Musick
Cruising
I can be driving down the road and the car keeps running but all my head lights shut off and I lose all dash lights. then they all come back and it wont happen for awhile.
Old Feb 26, 2020 | 04:50 PM
Landru's Avatar
Landru
Closely inspect starter connections.
Somewhat common complaint, especially w/ cars in warm climates and/or w/ headers.
Solenoid connector's are made of bakelite, get brittle w/ age & repeated heat cycles & fail.
Right now it may not be completely broken, giving intermittent outages.
Eventually it'll completely crack/break causing a total and permanent loss of power.
Get it in the air, confirm connections are solid, use a flashlight & pliers to gently tug/test lugs & poles.
If battery's left connected be damned carful not to inadvertently ground on anything while probing/checking.
Be in even bigger trouble if it does, so be careful.
If securing lugs are tight can rule out starter and must dig deeper.
Old Feb 27, 2020 | 10:00 AM
bravo29's Avatar
bravo29
Grounds or starter connection. Same dam issue on my C5. The connections at the started were loose and frail.
Old Mar 3, 2020 | 09:29 AM
Randall Musick
Cruising
Well found the Problem, it was at the Battery the positive side it was just lose enough that when it heated up from charging it would wiggle and lose connection.
Old Mar 3, 2020 | 03:45 PM
EviLS7's Avatar
EviLS7
Thats why use a rubber mallet to knock the connectors down on the posts before tightening. Good to hear it was a simple fix.
Old Mar 3, 2020 | 07:48 PM
1Willy1's Avatar
1Willy1
it just happeend to me as well, very similar isses, except it took me alot longer to find the issue
I was about to type it to you to check the batttery connections but you figred it out already , congrats
To Vette needs help.
