I have 2009 base corvette it has 65k miles on it and around 70mph is has a slight/light vibration that comes and goes every couple seconds . Any ideas of what I need to look for first The tires Michelins with 10k on them Thanks
Originally Posted by Iceaxe
If you shift to neutral and coast does the vibration stay or disappear?
Originally Posted by tmaples
I will check have not tried that
Exactly the same problem. 2005 MN6. I've tried everything and it only happens (for me) when cruise in gear. Stops immediately when I push in the clutch and doesn't happen if I rev the engine then.
It acts to me like a bad U joint in the driveshaft which obviously Corvettes don't have, but just guessing here it does have me thinking torque tube.
Not trying to argue that it is not the tires, but just have a discussion. Why would the problem stop if you push in the clutch and it goes away. Further if I go ~80+ does it get smooth again. I would think tires would not be harmonic and would always cause the vibration at any speed.
my car is a automatic so I cant pust the clutch in I really lsot because its onlt aeound 65-70 mph and it dont feel like a tire but I guess I will have it checked out
It my case it feels like the entire car, rather than a single area. (Definitely not the steering wheel). I can easily see the vibration in the rear view mirror. It is about BRrrrrrr - two seconds - BRrrrrr - two seconds etc. The first time I felt it I thought it was small ripples in the pavement.
I appreciate all the comments so far, it makes me think beyond my own ideas about the problem. Keep them coming please.
( Just thinking out loud .... since the OP has a automatic, I have a manual, and assuming its not the tires the only thing we have common is the torque tube. I've ordered new guibos and bearings which I should get in a week. Maybe when I take it apart I'll know more ---- if the torque tube is the problem )
No... but you can shift to neutral, which accomplishes the same thing.
Not to be a smart ... but maybe take it to a trusted mechanic. Or at least have someone who has a good knowledge of cars drive or go on a ride with you to narrow it down. You didn't even know that shifting to neutral has a similar effect to pushing in clutch.
Your thoughts please?
A tire that is not balanced properly can vibrate at a certain speed with that vibration going away at a different speed. Happens all the time.
So true. I had tires on a Toyota Tacoma that were out of balance but you could only feel a noticeable vibration 60-70 mph.
Also tires ca vibrate from things like separation or nonuniform wear not just being out of balance.
I had the exact same problem. Seems the previous owner had put fix a flat in the right rear . No way you can balance with that crap in there. Replaced both rear tires, road force balanced and smooth as silk.
Check the shocks. Worn shocks can set up a vibration that seems like out of balance tires. Your mileage is just about right for the OEM shocks to fail.
