Shift Cable Part #
Old Jul 24, 2020 | 02:12 PM
TripleB5832's Avatar
TripleB5832
Default Shift Cable Part #
I have a colleague that has a base 2005 C6 and he has encountered the shift cable breaking. His A4 will not change gears, is stuck in park, and he had determined the culprit is the shift cable. Does anyone have the part number readily available? He is not much for technology, hence the reason I'm asking on his behalf. Thanks in advance.
Old Jul 24, 2020 | 02:50 PM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
Shift Control Cable
10352529
Get it here, https://www.cultragfactoryparts.com/ Forum Vendor, but does the shifter move easily, or is is stuck in Park. If stuck in park it is not the cable. If it moves easily, has he checked the cable grommet at the shifter and the transmission? They are more likely the issue unless he has replaced them lately.
Old Jul 24, 2020 | 02:52 PM
Bronk's Avatar
Bronk
Is he certain it is the shift cable? I believe the gear shift lever will shift from park with a broken cable, but fail to "select" positions for engagement (the lever will feel unattached and move very easy through the selector). You friend may be experiencing the dreaded "stuck in park" issue instead.
Bronk
Old Jul 24, 2020 | 06:27 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
Bronk
When my 05 cable broke, the shifter moved freely, but wasn't engaging any gears. we stuck in neutral with shifter free!
Old Jul 24, 2020 | 08:46 PM
TripleB5832
Thank you to each of you gents for the responses. I’ll let my colleague know, looks like he may need to do some more diagnosing.
Old Jul 25, 2020 | 12:39 PM
irok's Avatar
irok
The shift cable for the 05 cars has been discontinued and is no longer available from GM or any one else.Time for your friend to find a new car
Old Jul 25, 2020 | 01:05 PM
Iceaxe's Avatar
Iceaxe
Where do you guys get this **** from??? They are available from multiple source for under $100. I know Ekkler has them.
I can make you a promise that any common part that is often replaced will be available on the C6 for at least the next 50 years so long as someone can make a couple bucks off it.
Old Jul 26, 2020 | 03:58 PM
irok's Avatar
irok
Several members on here in the last few months have not been able to get them including one car with 8,000 miles on it that had been sitting for a few weeks already with no cable available.Several of the GM sites on line show discontinued and no longer available.Eckler's also show's no shift cable p/n 10352529 available
Old Jul 26, 2020 | 04:20 PM
Iceaxe's Avatar
Iceaxe
2005 Corvette shift cable.
https://www.ecklerscorvette.com/corv...E&gclsrc=aw.ds
Old Jul 26, 2020 | 05:04 PM
cdm747's Avatar
cdm747
St. Jude Donor '17-'18-'19-'20-'21-'22
Anytime I have ever tried an Ecklers link it always goes to their home page. The link will not bring you directly to the part. Not sure why.
Old Jul 26, 2020 | 05:55 PM
jimijam's Avatar
jimijam
What part of post #2 can't you figure out? Click the website link, enter the part number in the search bar, and hit enter. Boom! It IS that easy. Part is $67.21
Old Jul 27, 2020 | 09:12 AM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
I just had mine replaced a few months back. had it done in a day. So the part is available.
Old Jul 27, 2020 | 11:39 AM
irok's Avatar
irok
Things change in a few months.Call any GM dealer or warehouse and they all claim there are no cables available
Old Jul 27, 2020 | 12:17 PM
Iceaxe's Avatar
Iceaxe
Dude... your defending an indefensible position... everyone is telling you the shift cables have always been available, you just had to know where to look... Yeah, we all get it the GM supply chain dried up... but suppliers immediately stepped up when there was a dollar to be made.
The cables have always been available from the numerous companies who build custom motorcycle cables. That is one of the best items of this forum is you can find a solution to just about any problem... just ask.
Old Jul 27, 2020 | 01:04 PM
jimijam's Avatar
jimijam
Give it up, man. The cables are available today. https://www.cultragfactoryparts.com/...cable-10352529
Old Jul 28, 2020 | 04:50 AM
irok's Avatar
irok
Try buying one.They are not available from Culrag, any GM dealer or GM warehouse
Old Jul 28, 2020 | 07:01 AM
2012er's Avatar
2012er
Veteran: Marine Corps
https://www.zip-corvette.com/06-13-a...ter-cable.html
To Shift Cable Part #
Old Jul 28, 2020 | 10:05 PM
jimijam's Avatar
jimijam
Wrong! Nice try, kid.
Old Jul 29, 2020 | 10:48 AM
irok's Avatar
irok
What part about not available do you not understand?Got email from Cultrag saying they are not available from GM.You would be sitting on the side of road some where for a long time before Cultrag sends you one
Old Jul 29, 2020 | 11:01 AM
Iceaxe's Avatar
Iceaxe
Give it up dude... GM Parts direct for $58.
https://www.gmpartsdirect.com/oem-pa...cable-10352529
