Wide body Conversion
SS Vettes
Super Vettes
California Super Coupes
RPI Quarters
I was considering:
OEM Front Bumper
SS Vettes front fenders and install kit
RPI paint matched Quarters.
Fitment on the SS-Vette was OEM.
ps, I also got the SS-Vette front inner fender well that glues to the body, some guys just glue an extension on as you aren't going to see it anyway, but I went the extra step and removed the OEM and installed theirs so the liner is flush with the front fenders.
r yourself.
-Pioneer ND-BC8 back up camera
-Optima Yellow Top Battery
-Holley Terminator-X Max ECU
-AMT Vulcan Motor Mounts
-Dewitts Radiator
-Corsa Extreme 3” Exhaust
-Hooker Blackheart Tri-Y 2” Headers w/ARP bolts
-Hooker Blackheart 3” Race X-pipe
-Viking Double Adjustable Coilovers
-Eibach Sway Bar Kit
-Pfadt Adjustable Sway bar links
-ECS Rear Differential Brace
-Powerstop Slotted/Cross Drilled Rotors
-Wilwood 4 piston Calipers
-Stop Tech Stainless Braided Brake Lines
-TSW Nurburgring Wheels
-Continental Extreme Contact Sport Tires
-NGK BR7EF Spark Plugs
-MSD 8.5mm Plug Wire Set
-MGW Short Throw Shifter
-OMP Shift ****
-Corbeau Evolution X Racing Seats
-Vanaram Cold Air Intake
-BTR Double .660 springs
-BTR Titanium retainers
-BTR Chromoly pushrods
-LS7 Lifters
-Straub Technologies Trunion kit
-BES Stage 3 ported CNC 243 Heads
-ARP studs and fasteners
-Tick Polluter Camshaft
-Lingenfelter C5R Timing Chain
-Fast LSXR 102 Intake
-Holley LS Fuel Rails
-Melling Oil Pump
-Improved Racing Oil Pan Baffle and Crank Scraper
-Walbro 450 Fuel Pump
-Racetronix Fuel Pump Relay and Harness Kit
-Skunk 2 Mechanical Fuel Pressure Gauge
-Nick Williams 102 Throttle-body
-FIC 1000cc injectors
-Nitrous Outlet Fast 102 plate kit
-Nitrous Outlet Purge Kit
-Nitrous Outlet Bottle Heater
-Nitrous Outlet Filter
-Nitrous Outlet blowdown tube
-Custom Nitrous Switch panel
-RPM Stage 4 Wave track Differential 4:10
-SLP Under-drive 25% Pulley with ARP bolt
-ASP Over-Drive Alternator Pulley
-160 Degree Thermostat
-Comp Cams Billet Idle Tensioner and Pulley
-McLeod RST Clutch
-McLeod LS Flywheel
-Tick Clutch Master Cylinder
-Mighty Mouse Wild catch can
-AEM Electronic Fuel Pressure Gauge
-AEM Wideband Air/Fuel Ratio Gauge
-Holley LS Valve Covers
-GM ZR1 Rear Spoiler
-IPCW LED Tail lights
-Carbon Fiber Side Skirts
-RK Sport Violator Hood
-C7 Carbon Carbon fiber front splitter
This is almost exactly the same approach I took. I actually bought my SS-Vette ZR1 front fenders based on David's recommendation.
These made the most sense over OEM because GM charges a fortune for the stock CF fenders. The highly regarded Corvette specialty shop that did the work said they were the best fitting aftermarket panels they had ever seen, and they had no cosmetic issues.
The prices from Gene Culley for the rest of the OEM 'widebody' kit were very reasonable.
And customer service with both of these vendors was excellent.
SS-Vette sells front fender liner extensions for about $100/pair and I took the easy way out on this.
