Door cable
Old Aug 22, 2020 | 04:13 PM
craftsman74066's Avatar
craftsman74066
Default Door cable
Has anyone opened there trunk lid and pulled on the door cable to see if it opens the door?
Old Aug 22, 2020 | 04:15 PM
Vette_DD's Avatar
Vette_DD
Yes, did that with each C6 that I had. They all worked okay.
Old Aug 22, 2020 | 05:22 PM
HBsurfer's Avatar
HBsurfer
Yes
Make sure your key opens the truck too.
Old Aug 22, 2020 | 05:29 PM
ruxvette's Avatar
ruxvette
2016 C6 of Year Finalist
Originally Posted by HBsurfer
Yes
He's got a truck, too?
Old Aug 22, 2020 | 05:58 PM
2008 Corvette's Avatar
2008 Corvette
2020 C6 of the Year Finalist - Modified
Default Cable
No. Never tried it. Afraid the door will fall off.
Old Aug 22, 2020 | 05:59 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
I used the emergency door handle, after I got in closed the door, hit start, and everything went dead. I had to use the handle to get out, battery stone dead.
Handle worked!
Old Aug 22, 2020 | 06:13 PM
saplumr's Avatar
saplumr
Handle worked!
He’s talking about the hatch door lever.
Old Aug 23, 2020 | 10:15 AM
Kenny94945's Avatar
Kenny94945
FWIW.
Might be a good idea for all owners to locate and check these emergency pull cord/ cable systems.
Emergency pulls:
Fuel door in trunk
Drivers door in trunk
Rt & Lt Door handles on passenger compartment floor.
Trunk/ hatch behind dirvers seat?
Vert, is there a pull for the tonnoue cover (sp) behind waterfall?
AND test access with your emegency metal key lock above the rear license plate area.
Any list errors or did I leave something off the list?
No, I have not tested these systems myself in years.
Will do so thanks to this thread.
Old Aug 23, 2020 | 01:04 PM
FatsWaller's Avatar
FatsWaller
Originally Posted by Kenny94945
FWIW.
Emergency pulls:
Fuel door in trunk
Emegency Brake aka parking brake
4 way flashers
Actually,, there's lots of stuff that should be checked periodically. Lights, treadware, fluid levels, belts, hoses, and so on.
To Door cable
