Wheel questions.
Old Sep 20, 2020 | 12:11 PM
2012GSwhite's Avatar
2012GSwhite
3rd Gear
Default Wheel questions.
I bought a set of z06 wheels and tires for my 2012 GS. Tire sizes are the same on both sets. Will I be able to bolt these straight on the car? Will I need to have the tire pressure sensors set to the need wheels?
Old Sep 20, 2020 | 12:31 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
Not only do the GS have the same size wheels as the Z06, but the offset is the same too ... they will bolt right up
As far as TPMS sensors, there was a change in the freq. they work at sometime in 2009 ... If the Z06 wheels are from an early Z06, they might not work (wrong freq). If they are from a later model year Z06, they will work.
You will still need to have them electronically matched to your GS to get them to work. Either buy a TPMS reset tool (eBay for about $9) or pay someone like Firestone to reset the TPMS sensors to your car.
Old Sep 20, 2020 | 12:46 PM
2012GSwhite
3rd Gear
Thanks, that’s what I was hoping. Came off of a 2013 Z06 said put new sensors in the wheels.
Old Sep 20, 2020 | 05:13 PM
Turbo6TA's Avatar
Turbo6TA
Your good to go ... and the wheels will be in the same position in your wheel wells as the OEM wheels you now have on the car.
Just need to get the TPMS sensors mated to your GS.
Old Sep 20, 2020 | 05:16 PM
Turbo6TA's Avatar
Turbo6TA
Just for your info ... The offset for the GS / Z06 front wheels is +40mm
For the rear, it's +59mm
Old Sep 20, 2020 | 06:37 PM
2012GSwhite
3rd Gear
Thank you all your info was greatly appreciated!
Old Sep 20, 2020 | 07:48 PM
Turbo6TA's Avatar
Turbo6TA
BTW .....
Here are a set of OEM Z06 "Spyder" wheels that used to be on my 2011 GS:
Attachment 48336725
To Wheel questions.
By Michael S. Palmer | 2026-06-03 11:00:24
