Muffler delete question
Old Nov 20, 2020 | 12:46 AM
Ahnenerbe's Avatar
Ahnenerbe
Default Muffler delete question
Hey guys, I have been searching and can't find any answers. I am wanting to remove the mufflers on my 06 convert and go straight pipe to see how I like it. How is this done? Is there a kit I can buy or will I need to take to a shop? Thanks for any help.
Old Nov 20, 2020 | 01:51 AM
jorgez28's Avatar
jorgez28
The mufflers are easy to remove a shop can do it but the exhaust tips are going to be a chore. It would be easier to get straight pipe an axel back that you could install yourself. There is also a muffler mod I’m sure someone can link to that is cheaper.
Old Nov 20, 2020 | 03:53 AM
Texan79423's Avatar
Texan79423
I had a muffler shop cut mine out. $275.00 with new 3 inch tips. I admit it is loud but with my BTR stage 3 cam it sounds great and people compliment me all the time.
Old Nov 20, 2020 | 04:22 AM
Holster Maker's Avatar
Holster Maker
My first choice for the no-muff exhaust would be these:
https://www.carid.com/2008-chevy-cor...parentsubmodel=ENGINE|6.2L
$720 isn't bad with the work all done and resonators.
Yes, you can go to a GOOD muffler shop for the job!
Your car is the 05-08 exhaust direct bolt on, even though the '08 is diff motor!
A good muffler man can make you a set, like jorge / tex said, the chore (time) in all the welding / cutting and adding the four outlets, if your want them. It might be getting close to the direct bolt-on price with some added resonators to help with drone-ness. Actually they work great, not as loud as you would think w/stock motor, if you keep your foot out of it. And a lot lighter.
Old Nov 20, 2020 | 05:53 AM
449er's Avatar
449er
CF Community Team
I hope you like lots of noise, not a mod that I would consider doing
Old Nov 20, 2020 | 06:19 AM
Cockroach's Avatar
Cockroach
I recently purchased from a forum member a spare set of Z06 mufflers, cut them open and did the youtube muffler mod. Swapped them with the Z06 mufflers I added to my base model and am pleased with the added tone and louder (no drone) exhaust note. With the npp closed it retains the factory level sound (wife is happy) but open really wakes up the exhaust. Very pleased with having the best of both worlds.
Old Nov 20, 2020 | 07:39 AM
iwantaz06now's Avatar
iwantaz06now
I might have a customer getting rid of his straight pipes in a few months if you can wait.
Corsa Xtreme is also a great option with similar volume to straight pipes without the drone associated with cutting out mufflers. I'm doing holiday deals if you're interested in going that direction.
Old Nov 20, 2020 | 10:51 AM
2008 Corvette's Avatar
2008 Corvette
2020 C6 of the Year Finalist - Modified
Default Exhaust
Are you a Forum Vendor ?
Old Nov 20, 2020 | 11:08 AM
pdc001's Avatar
pdc001
I've done it. A shop will basically just cut off your OEM mufflers and then bend a new tube and weld from there. There is drone to it so you better be ok with it. Under very very light load there is hardly any drone.
Old Nov 20, 2020 | 01:18 PM
oAllElseFailo's Avatar
oAllElseFailo
All the vendors i've seen have it stated on their profile in red like 'supporting vendor' so i'm going to say no, he's not.
Old Nov 20, 2020 | 01:22 PM
2008 Corvette
Default Mufflers
Most of us know this. Why did you answer this when the question was not addressed to you ?
Old Nov 20, 2020 | 01:26 PM
oAllElseFailo
Sorry for sharing my .02. yikes.
Old Nov 20, 2020 | 01:31 PM
Topduarte's Avatar
Topduarte
I am planning to do this also. Only difference is I want that pipe to be clamped on both ends just in case I want to go back and add the mufflers. Just need to save. Exhaust shop was gonna charge me $500 for removing mufflers and adding straight pipe.
Old Nov 21, 2020 | 02:22 PM
HOXXOH's Avatar
HOXXOH
Don't over-think this. Remove your current mufflers w/included over-the-axle pipe and set them aside. Your OEM pipe/mufflers can sit in your garage unmolested until you want to return the car to stock. Then simply buy used muffler/over-the-axle pipes and let the muffler shop cut off the mufflers and weld in a connecting pipe and new tips of your choice. Much less initial expense and easier to swap back later. If you decide to go back to stock, you'll also be able to sell the straight pipes to someone else who wanted to do the same thing. If you like the straight pipes forever, you can sell the OEM ones.
I'd sell my straight pipes with 4" tips for $100 (that I only used for a couple months on my '08) for local pickup or if you handle/pay the packaging/shipping.
Old Nov 22, 2020 | 05:10 PM
lobstah24's Avatar
lobstah24
Best answer right ^^^there^^^.
Old Nov 22, 2020 | 08:12 PM
Mad*Max's Avatar
Mad*Max
I would think there will be a lot of drone.
Old Nov 22, 2020 | 08:36 PM
saplumr's Avatar
saplumr
I like loud but there’s not a chance in h#ll I delete my muffs. I have Corsa Xtreme and when I want LOUD I have ECO’s.
To Muffler delete question
