Help with Driver Side Window
Old Dec 21, 2020 | 03:54 PM
physicsteacher33's Avatar
physicsteacher33
Cruising
Default Help with Driver Side Window
Every time I get out of my vette the driver's side window goes up and down about an inch for 4-5 times. I have to start the car to get it to stop. Why is this happening and how can I fix it.
Old Dec 21, 2020 | 04:03 PM
ClothSeats's Avatar
ClothSeats
Have you tried indexing the window?
Old Dec 21, 2020 | 04:05 PM
Vette_DD's Avatar
Vette_DD
With the engine running and the window down, close the car door. Raise the window and hold the up switch an extra 3 seconds. Release. Without lowering the window, hold the up switch again for 3 seconds. Release. Done. Don't forget the other window.
This will need to be done to both windows every time the car battery is disconnected, then reconnected, or when a new battery is installed in the car.
Old Dec 21, 2020 | 04:08 PM
MKenM's Avatar
MKenM
St. Jude Donor '12-'13-'14-'15-'16-'17-'18,'21
Two things to try. 1st. Re-index the window as follows.
1. Close the doors.
2. Raise the window and hold the switch up for three seconds after the window is closed.
3. Release the switch, then hold the switch up again for three seconds and release.
or disconnect the battery and then re-index the windows.
To Help with Driver Side Window
