2008 Suddenly will not start
A few days ago I drove the Corvette on a 3 hour drive in 40ish degree weather. When I arrived at my destination I shut it off. After about 5 minutes I tried to start it and got nothing but the same thing many others get which are indications that the battery is still charged and everything is engaging but the starter. My fix, I believe was to put the car in Neutral from Acc mode and it started. I left and 10 minutes later turned it off again to get gas. When I tried to start again I got no starter engagement. This time the neutral situation didn't work. I maneuvered the gear selector a few times without success. After a few minutes of this I put it back in park and it started.
I've tried to recreate the problem but so far it hasn't reoccurred. In addition, I haven't had any problems with the shifter sticking in park. I am under the impression that the no-start issue is in connection with the switch circuit that sometimes doesn't engage or disengage the trans lock. I, however, haven't run across another post by someone connecting the two and now wonder if it is just a coincidence.
Can anyone with the same experience shed some light? Thanks
There are 2 tiny micro-switches at the stem of the shift lever that need to be engaged in order to activate the starter motor. If you listen very quietly, you can hear them click as you move the shift lever into Park.
I had a problem with one of these switches - I got a "shift to park" message on the DIC.
I'm assuming this is not a battery or battery cable issues like corossion.
M...
GD
