c6 battery change
Old Mar 16, 2021 | 10:02 AM
edsrottie's Avatar
edsrottie
5th Gear
Default c6 battery change
I changed my battery in my c6 everything dead. New battery new forb batteries still nothing works. How do you fix it.
Old Mar 16, 2021 | 10:11 AM
Vette_DD's Avatar
Vette_DD
Disconnect the new car battery and leave it disconnected for about 10 minutest or so. Then reconnect, making sure you've got the connections tight.
Remember to reset the window indexing for both windows after the electricity returns. That's all that should need to be reset.
Old Mar 16, 2021 | 10:25 AM
hawkgfr's Avatar
hawkgfr
Did you blow a fuse? Installed battery charged?
Old Mar 16, 2021 | 11:00 AM
oldcanuck's Avatar
oldcanuck
Connection of the cable to the battery can be difficult. I had to really check mine as I thought negative connection was tight but it actually wasn't.
Old Mar 16, 2021 | 12:42 PM
dr_gallup's Avatar
dr_gallup
Is the new battery fully charged?
Old Mar 16, 2021 | 01:44 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
This might be a stupid questions, but you remove the black that was over one battery pole.
It might look has it wasn't there, but it is, and battery will appear dead.
To c6 battery change
