Should I be concerned?
Old Mar 29, 2021 | 11:29 PM
N8 Wavy's Avatar
N8 Wavy
Default Should I be concerned?
After a cruise around the city (Ventura) I checked my temp gages & these are what read.
It seems a little high to me but I’m no expert. Anyone else get similar number from city driving?
Old Mar 29, 2021 | 11:42 PM
Vette_DD's Avatar
Vette_DD
No, those numbers are all okay for driving around town.
Old Mar 30, 2021 | 12:28 AM
hawkgfr's Avatar
hawkgfr
What he said...you can get the average water temp down about five degrees by removing the rail covers for free...
Old Mar 30, 2021 | 12:52 AM
N8 Wavy's Avatar
N8 Wavy
Thanks for the tip, does 5 degrees make a difference?
Old Mar 30, 2021 | 12:54 AM
2008 Corvette's Avatar
2008 Corvette
2020 C6 of the Year Finalist - Modified
Default Concerned
Originally Posted by hawkgfr;[url=tel:1603224798
1603224798[/url]]What he said...you can get the average water temp down about five degrees by removing the rail covers for free...
. How do you figure removing FRC’s will drop water temp ? Please explain.
Old Mar 30, 2021 | 01:13 AM
vetteJPJ's Avatar
vetteJPJ
I think that is high unless you are in a very hot region or stuck in traffic. 228 during normal driving around in city? I'd take a look at coolant level. Maybe test the coolant.
Old Mar 30, 2021 | 01:34 AM
N8 Wavy's Avatar
N8 Wavy
I’ll check the coolant level tomorrow morning, I’d like to note that I’ve been driving with the paddles a lot recently to hear the rev matching downshifts. Also just installed a Pedal Commander and have had it set to Sport lvl 2 not sure if this has any effect on this.
Old Mar 30, 2021 | 01:51 AM
2008 Corvette
Default Temps
Originally Posted by vetteJPJ;[url=tel:1603224861
1603224861]I think that is high unless you are in a very hot region or stuck in traffic. 228 during normal driving around in city? I'd take a look at coolant level. Maybe test the coolant.
. Look again. The 228 is oil temp not coolant. Oil temp is usually 15 to 20 degrees above coolant temp. Perfectly normal.
Old Mar 30, 2021 | 03:24 AM
cheetah45's Avatar
cheetah45
On a 60 degree day at 75mph on the freeway, I was seeing 225-230 on the oil temp guage in 2011 grand sport automatic.
Old Mar 30, 2021 | 08:22 AM
Red08's Avatar
Red08
I drove in a couple of parades with my C6, and both the oil and coolant temp went higher than I was comfortable with. Once I left the parade and drove down the street towards home, everything dropped. it just needed air. BYW, I have since quit doing parades.
Old Mar 30, 2021 | 09:23 AM
HYRYSC's Avatar
HYRYSC
Spirited driving with paddles always raises temps because more often than not you are holding revs higher than the factory shift points. I think this is pretty normal. The only one that I would be a bit uncomfortable with would be the Trans Temp which would be easily solved with a cooler.
Old Mar 30, 2021 | 09:52 AM
N8 Wavy's Avatar
N8 Wavy
Interesting, I’d imagine GM engineered these cars to withstand high temperatures but I’m concerned if it’ll lower the life expectancy of the engine/tranny.
Been doing a lot of spirited driving recently after installing the PC. I’m curious if the temp’s would drop if I were to leave it in D or S without activating the paddles, leaving the engine’s RPM’s in coast majority of the drive.
Also is it worth investing in a cooler for the tranny or will the car operate for just as long without it?
Old Mar 30, 2021 | 09:57 AM
acroy's Avatar
acroy
Nah it's fine.
Old Mar 30, 2021 | 10:32 AM
drewz06's Avatar
drewz06
thing knower
thats hotter than i'd like to see personally.... i honestly never see those temps in florida during the summer being stuck in traffic....
to be safe i'd check your fan and fluids... maybe add some water wetter.....
edit: i'd still check, but my z06 oil temps never got that high... of course, i've got the dry sump with a cooler...
Old Mar 30, 2021 | 10:46 AM
Texan79423's Avatar
Texan79423
I was told to not get concerned until oil hits 240. My C6 Z51 runs 197-202 water temp and 220 Oil regularly.
Old Mar 30, 2021 | 06:52 PM
z06clif's Avatar
z06clif
Is one of your tires flat?.....I see a tire icon in the display
Clif
Old Mar 30, 2021 | 07:08 PM
N8 Wavy's Avatar
N8 Wavy
Clif
Tire pressure monitor goes off randomly at times, although tires are fine
Appreciate the concern Clif
To Should I be concerned?
Old Mar 31, 2021 | 10:40 PM
1rusty1's Avatar
1rusty1
I have temps like that ever since I've owned the car. Slightly higher when a put on a front plate.
Old Mar 31, 2021 | 10:45 PM
buckmeister2's Avatar
buckmeister2
J...228 was his oil temp. what coolant is he supposed to check for that???
His "coolant" temp was 217, which I still think is a bit high for driving in Ventura, unless he was in traffic some. But, it is not high enough to worry about.
Old Apr 1, 2021 | 09:38 AM
N8 Wavy's Avatar
N8 Wavy
Recently with everything opening back up in the county there’s been lots of traffic. Also I’ve been having fun listening the the downshifts on the back roads of Ventura. I’ll be leaving the car in S w/ OUT activating the paddles to see if temps will drop.
