Been experiencing issue for opening the doors on 07 Z06. Fob batteries have been replaced numerous times thought perhaps that was the issue. Sometimes door opens, sometimes if held for longer period, Have had to use trunk access on occasion. Car battery is old but kept on trickle charger, car fires up immediately. Any knowledgeable people out there before searching internet or dealer? Thanks
More details needed. Is this a problem just with pressing the fob buttons, or is it with the external pressure pads, or both? What exactly are you doing that doesn't open the doors?
apparently if you can not open it from either the outside or inside then its the door latch assembly which still makes me curious because you should still be able to use the emergency latches?
Fixed the door issue....Found Corvette Forum Thread on Internet which I was unable to find on the Website.
Disassembled the pressure pads cleaned boards......Like New
