MRC not working, help
If the selector **** is not working, or disconnected, the BCM data will state the system is in touring mode.
So by flipping the switch back and forth with the motor started (or in run mode/motor off), you want to see the BCM change from touring to sports mode.
Next, pull up the F55 module and do a data look at it next. The F55 module gets it command from the BCM on what mode it should be in, and it too should show a switch from touring to sport with the selector flipped.
If mode is not changing in the F55 module data, start by going into BCM set up with tech II/Tech2win, and make sure that real time dampening is selected in the RPO codes.
Skip to the part about using a Tech II
If real time dampening is selected, the next it to check the F55 module wiring from the BCM to the F55 module.
Hence may have been a problem in the F55 system, and instead of the old owner solving it, just went into BCM set up to just turn it off to stop the codes/why the system is not working. Or, could have have been a BCM replacement/ or firmware reflash, and someone did not go into the BCM set up RPO list afterwards to make sure everything on the car was correctly selected.
Hence on the C6, you can turn the F55 system off, while still leaving all the parts in play.
As for why one would remove the MRC shocks/ the F55 system, most of the times is due to at least one of the MRC shocks needing replacing, where your looking at $500 per shock. Other times, it's taking a base car up to at least a Z51 level suspension system or better for increased handling.
So the RTD system was a cross between a soft ride in tour (for a vet, which is still a rougher ride) and slightly firmer for sport driving, but was not on the same level as just a Z51 option car when it comes to handling.
Could have been that the MRC shocks where removed/B8 shocks installed, F55 programmed out in the BCM, but selector **** and F55 module left in the car.
On the top of every shock, should be a electrical connector, and again, F55 module/RTD should be selected in the BCM programming RPO list.
I don't track mine, just streets and twisties.
I have a 2010 base with MRC and Jim Mero's Super Sport reprogramming. The shocks are the same PN as on a Z06. I have it on good authority the springs on the base with MRC are the same as the springs on a 2012 Z06 with MRC. The bars are not, 25.5 mm front and 17.5 mm rear. I am changing the bars this week to a 33 mm ZR1 front and an adjustable (400 to 775 lb) MuscleBar on the rear. I have 265 front and 345 rear tires.
Didn't mean to hijack your thread.
On the base models, it was the other way, with base type suspension, and then MRC shocks add to it (why even the Z51 will out suspension handle than a base model with just MRC shocks).
As for wide body, verses narrow body, lot of difference in the amount of tire grip available, so F55 tune will need to be different between the two.
If Mero can come up with a tune for how you plan to run, Great, but would rather see an after market module/some other type of tuner with more end user type control that one could tweak the settings at needed to dial in the car from track to track isntead.
as soon as all of that was fixed, i had my MRC working properly again.
with the current set up ( installed a year ago ), the sport still has too much play in it for me. but i when i really get on it, when driving club driving on the back roads, it firms up quite a bit.
i've surprised more than few fellow drivers with, how well the car handles. this also has surprised why others are surprised, it is a corvette, and a C6 one too.
i think people may think because of its width, it carries a bit more weight. obviously not so.
for now, i'll stay with the current set up ( Jim Mero ). i feel it may be geared more towards the people who want a smoother ride and, may not push it too much.
In my case, MRC was working properly before I stored the car for winter. Jim reprogrammed it in Dec. It wasn’t until getting the car out this spring that I noticed a problem.
