Black or beige
Difficulty: Budget $50 so you don't mind doing it twice. It is exactly the same as trying to get a very wide (IIRC like 24"x36) piece of tape down flat.
I did mine myself. For the console, I used 3m Di-Noc 3d carbon fiber wrap. Good luck deciding I hope this helps.
This is a couple of years later so you can see how it holds up. (I added a 2012 wheel at this point)
Close up:
But I'm truly incompetent when it comes to stuff like this ..."A man's got to know his limitations." --Dirty Harry Calahan... and I know mine. The chances of me hosing it up and ending up having to pay a professional to undo what I've done and then do the job (I should've just paid him for) in the first place are awfully high. So you 'get a wide piece of tape flat', then what about the cut outs for the vents, etc.?
My big concern is keeping it one piece with the shape of the console. Did you start at the top near the vents, at the back near the tombstone or on one of the sides? I have watched a couple videos on how to wrap dash and console pieces. It looks like I need a heat gun, a sharp utility knife and a squeegee.
I also recommend changing the color of the other gray components (door buttons, e-brake button) to coordinate.
Matte black vinyl wrap
Painted Rustoleum Night Black Metallic
Painted
I would use a hair dryer rather than a heat gun. The heat gun can make the wrap so soft that you can easily tear a hole in it. BUT, heat is your friend here and really helps get that nice tight look. After you cover a hole slit wrap in the center and wrap around the edge. Leave a fairly large tab on the back side because the wrap will shrink ever so slightly.
Here's an example of the tabs I left on the tombstone.
If you chose to do paint I would opt for the flat with matte clear on the small pieces and then either satin or actual body color for the console.
Here is the process I used and all paint was rustoleum.
1. 600 wet sand your part until the sheen is gone
2. Spray with adhesive promoter and within 10 minutes a coat of primer, another 10 minutes primer again. Follow the primer process until it looks like you have good coverage,
3. Let dry over night
4. 600 wet sand to smooth out primer.
5. 3 light coats of color spread out every 10 to 15 minutes
6. Wait 30 minutes to an hour until the top coat looks evenly dry and apply 2 coats of clear about 10 or 15 minutes apart.
7. Let dry over night and hopefully done.
8. Caution if you use a matte clear spraying it on to heavy or to many coats your finish will look frosted.
Here is a pic of mine completed.
Also, I have been looking at the same center console cover you have. How do you like it? It looks so much more comfortable than the stock one.
