How hard can it be to get a street/track alignment?
I replaced the balancer on my GS over the summer which, of course, put the alignment out of whack. I bought new tires also to get ready for some upcoming HPDEs in Texas this fall. The Firestone store that installed the tires (did a great job--no impact and used my pucks) was not able to do the alignment as the ramps to their in-ground machine were bent. They said the parts were on back order. That's OK. I was going to be traveling on and off the next month, so no big deal. When I get back, they are still waiting on the parts. So....
I call the other two Firestone stores in the area that had in-ground racks. Made an appointment at a store about 30 minutes away, but it was a week and a half out. I show up for a 7AM appointment, the manager comes out, looks at my splitter and says 'No way. Not taking the chance." He wouldn't budge.
Just wonderful. Call Corvette World and ask them where they get their cars aligned. He tells me Five Star Chevrolet not far away. I call and the service writer he recommended said he could get me an appointment for the next day. Go in for the alignment and wait an hour for them to finally pull the car on the rack. About 30 minutes later the service writer finds me and says the tech won't do off-spec alignments. The GSM recommends an independent Porsche shop--RAC Performance. I take the info and head home.
Call RAC and they quote me $384 for an off-spec alignment. And I thought the Corvette tax was high. I decline and continue to look around. No one is willing to do an off-spec alignment? WTF?
I was about to give up and go with the EOM specs, but a few days later I get a call from the original Firestone store saying their ramps have been replaced. Do I still need the alignment. I make an appointment for this morning at 7AM.
They did a great job on the alignment and hit the specs exactly. So if you're in the North Texas area and need a street/track alignment for $100, go to the Firestone Store in Little Elm and ask for Eric or Andrew.
I was about to give up and go with the EOM specs, but a few days later I get a call from the original Firestone store saying their ramps have been replaced. Do I still need t he alignment. I make an appointment for this morning at 7AM.
I usually do my own but $100 is a great price and they are close.
Received 3,095 Likes
2021 C6 of the Year Finalist - Modified
If I need an alignment, I just take my GS to Firestone. I give then the Toe and Camber specs I want for the front wheels and the Toe and Camber specs I want for the rear wheels.
$100 and it's gets done.
And if I have a problem later (such as maybe pulling right or left) I just take it back to them and it's adjusted for free ... I think guaranteed for a year, or something like that.
ext (08-18-2021)
My Firestone will set the alignment specs to anything I want since I am the one paying for the alignment.
My Firestone uses an alignment rack that puts the car in the air, but it fits ok on the rack.
However, I don't have skirts on mine ... But it still sits pretty low with coil-overs on the rear.
Attachment 48331175
Attachment 48331175
In my town, finding a competent alignment shop is hard.
Plus w/ our C6s one needs a Tech II to align the steering sensor for that perfectly centered steering wheel.
Received 9,002 Likes
How high off the ground is your front splitter? The one & only shop I’ve taken my car to broke my OEM splitter. They replaced it but OEM parts are getting harder to find. And at $2k for the splitter I don’t want to take any chances.
http://www.customalignment.com/
The problem I had is that many shops, including some Firestone stores, still have the standard rack like this where the car must be driven over those steeper ramps.
The alignment tech did a great job and I have no reservations about recommending them.
It's the standard ZR1 splitter and it's 4.5" off the ground. The Firestone in Little Elm has this type of in-ground rack (below) that is perfect for low cars like ours. The small extensions that you drive over to get on the rack had gotten bent somehow, probably by a heavier vehicle like a 3500 or something. Anyway, their rack was down until they could get them replaced.
JABCAT (08-19-2021)
The splitter will scrape on some inclines, like driving into a parking lot from the street or the driveway. Trust me, it makes a very distinct sound that sounds nothing like the soft rubber of the air dam.
I have to be very careful especially around here. Getting into & out of my driveway is a chore because I have the large rolled curb where it meets the street. Thankfully I’ve got a mini cul-de-sac so I can approach at a very sharp angle. My side skirts will scrape exiting if not at a sharp angle. I plan to have the curb cut & re-poured flat.
