Key fob
Old Sep 13, 2021 | 08:39 PM
oledeadeye's Avatar
oledeadeye
Cruising
Default Key fob
I need to get a new key fob for my 2007 vette and am wondering if I will need to take it to a dealership to have it programmed? Anyone done this lately and how much? I’ve seen them for sale on the internet but not sure about the quality. Thanks for the feedback.
Old Sep 13, 2021 | 09:24 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
I bought my Fob from Amazon for 2005, and if I had problem easy return, and then went to u-tube and watched video, easy has pie, only thing after program you need to set all your memories with the new fob.
Old Sep 13, 2021 | 09:30 PM
gdmoore01's Avatar
gdmoore01
Below is a link to the owners manual for your 2007 C6. Page 75 describes how you can program a new key fob for your car once you purchase one.
https://www.corvsport.com/wp-content...ers-Manual.pdf
GD
Old Sep 14, 2021 | 06:10 AM
MKR_DmD's Avatar
MKR_DmD
Veteran: Marine Corps
I bought two of these for my 2007. $30 each.
Amazon Amazon
I first did a short program to make sure my glove box key insert was working, then I did a long program to erase all the memory and reprogram my fobs. Instructions are on this board on how to do a short and long program, very easy to do.
Old Sep 14, 2021 | 08:08 AM
oledeadeye's Avatar
oledeadeye
Cruising
Thanks for the info, I will check them out!
Old Sep 14, 2021 | 08:22 AM
blownbayou's Avatar
blownbayou
Make sure you trunk key mechanism works..... You need this to reprogram your fob. Mine did not work and I had to remove the back cover (carpet cover inside) and reach in and initiate the program by hand by pulling the lever five/six times.
Old Sep 14, 2021 | 07:43 PM
oledeadeye's Avatar
oledeadeye
Cruising
Just ordered my fob from a local Chevy dealer and should get it in a day or so, will review these tips and report back. Thanks to all!
Old Sep 14, 2021 | 08:09 PM
1972bluelt1's Avatar
1972bluelt1
https://www.amazon.com/gp/product/B08M85SM57
You can use the 2009 and later fobs on a 2007? Can the blank keys be cut for the 07?
To Key fob
