VIN decoder
TIA
TIA
https://www.corvetteforum.com/forums...YY26W385121289
[img]file:///C:/Users/APREA/AppData/Local/Temp/msohtmlclip1/01/clip_image002.jpg[/img]
2010 Chevrolet Corvette 2dr Cpe ZR1 w/3ZR
VIN: 1G1YN2DT9A5800488
Summary Style & Trim Equipment Colors Tech Specs
Narrow Down By Style 2dr Cpe ZR1 w/3ZR
General Information
MFR Model Code
1YY87
Body Type
2dr Car
Pass Doors
2
Alternative Name
ZR1 3ZR
Alternative Body
2dr Car
Drivetrain
Rear Wheel Drive
Original Pricing
MSRP
$106,880.00
Invoice
$99,932.80
Destination Charge
$950.00
3ZR upgrade $10,000.00
Engine & Powertrain
Type
8 Cylinder Engine
Displacement L/CI
6.2/378
Fuel Type
Gasoline Fuel
Horsepower
638.0 @ 6500
Fuel Economy
14.0 City / 20.0 Highway MPG
Fuel Capacity
18.0 gal
Net Torque
604.0 @ 3800
Tech Specs
Manufactured By
United States Chevrolet Passenger car
Suspension Type - Front
Short/Long Arm
Suspension Type - Rear
Short/Long Arm
Front Tire Size
P285/30ZR19
Rear Tire Size
P335/25ZR20
Brake ABS System
4-Wheel
Wheelbase
105.7 in 105.7 min 105.7 max
2dr Cpe ZR1 w/3ZR
ZR1 w/3ZR
Mechanical & Powertrain
Engine, 6.2L supercharged V8 SFI with dry sump oil system (638 hp [475.7 kW] @ 6500 rpm, 604 lb-ft of torque [815.4 N-m] @ 3800 rpm)
Rear axle, 3.42 ratio, limited slip
Engine access, rear-opening hood
Rear wheel drive
Frame, aluminum
Brakes, 4-wheel antilock, 4-wheel disc
Exhaust, dual-mode aluminized stainless-steel with 4" polished stainless- steel tips
Safety
Daytime Running Lamps
Air bags, frontal and side-impact, driver and front passenger with Passenger Sensing System (Always use safety belts and the correct child restraints for your childs age and size. Even in vehicles equipped with air bags and the Passenger Sensing System, children are safer when properly secured in a rear seat. Never place a rear-facing infant restraint in the front seat of any vehicle equipped with an active frontal air bag. See the vehicles Owners Manual and child safety seat instructions for more safety information.)
Tire Pressure Monitor System air pressure sensors in each tire with pressure display in Driver Information Center
Interior
Seat adjuster, driver 6-way power
Seat adjuster, front passenger 6-way power
Seats, heated driver and front passenger
Custom Leather Wrapped Interior Package features leather-wrapped upper instrument panel, upper door trim panels and console storage cover. Exclusive leather color and two-tone design includes seat headrest model-specific embroidery and enhanced armrest padding. Special gunmetal pattern console trim plate
Console, floor 2 covered cup holders, ashtray with cigar lighter, auxiliary power outlet and CD storage
Floor mats, carpeted
Steering column, power telescopic with manual tilt
Steering wheel, 3-spoke leather-wrapped
Steering wheel controls, mounted audio controls
Head-Up Display with dot-matrix readouts for street mode, track mode with g-meter, vehicle speed, engine rpm and readings from key gauges including water temperature and oil pressure
Instrumentation, electronic analog with Driver Information Center and 2-line display
Oil life monitoring system
Windows, power with driver and passenger Express-Down
Cruise control, electronic with set and resume speed
Memory Package, recalls 2 driver "presets" for 6-way power seat, outside mirrors and telescoping steering column
Universal Home Remote includes garage door opener, 3-channel programmable, located on driver visor
Hatch release, push button open with power hatch pulldown
Air conditioning, dual-zone automatic climate control with individual climate settings for driver and right-front passenger and outside temperature display
Air filtration system with pollen filter
Defogger, rear-window, electric
Mirror, inside rearview auto-dimming with compass, includes dual reading lights
Visors, driver and front passenger illuminated vanity mirrors
Lighting, interior with courtesy, cargo and glovebox
Storage, with lockable glovebox and center console
Cargo net and luggage shade
Exterior
ZR1 carbon fiber components includes roof, roof bow, front splitter and rocker extension with visible clear-coated carbon fiber weave pattern plus body-color dual front cove fenders, floor panel and raised hood with window
Headlamps, dual projector lamps, Xenon, High-Intensity Discharge (HID) low-beam tungsten-halogen high-beam with automatic exterior lamp control
Fog lamps, front, integral in front fascia
Mirrors, outside heated power-adjustable and driver-side auto-dimming, body- color
Glass, Solar-Ray light-tinted
Wipers, front intermittent
« Style & Trim
Colors »
Top of Form
Enter Torch Red
Red
70U
Ebony
195
Vehicle Name
Chevrolet Corvette
Body Style
2 Door Coupe
Drivetrain
Rear Wheel Drive
EPA Classification
Two Seater
Passenger Capacity
2 2.0 min 2.0 max
Passenger Volume
52.0 ft³ 52.0 min 52.0 max
Base Curb Weight
3333 lbs 3333.0 min 3333.0 max
EPA Greenhouse Gas Score
3 3.0 min 3.0 max
Fuel Economy Est-Combined
16 MPG 16.0 min 16.0 max
EPA Fuel Economy Est - City
14 MPG 14.0 min 14.0 max
EPA Fuel Economy Est - Hwy
20 MPG 20.0 min 20.0 max
Engine Order Code
LS9
Engine Type
Supercharged Gas V8
Displacement
6.2L/378.3
Fuel System
Electronic Fuel Injection
SAE Net Horsepower @ RPM
638 @ 6500
SAE Net Torque @ RPM
604 @ 3800
Trans Order Code
MN6
Trans Type
6 6.0 min 6.0 max
Trans Description Cont.
Manual
First Gear Ratio (:1)
2.66 2.66 min 4.03 max
Second Gear Ratio (:1)
1.78 1.78 min 2.36 max
Third Gear Ratio (:1)
1.30 1.3 min 1.53 max
Fourth Gear Ratio (:1)
1.00 1.0 min 1.15 max
Fifth Gear Ratio (:1)
0.74 0.74 min 0.85 max
Sixth Gear Ratio (:1)
0.50 0.5 min 0.67 max
Reverse Ratio (:1)
2.90 2.9 min 3.06 max
Final Drive Axle Ratio (:1)
3.42 2.56 min 3.42 max
Tons/yr of CO2 Emissions @ 15K mi/year
9.8 9.8 min 10.4 max
Short/Long Arm
Short/Long Arm
Suspension Type - Front (Cont.)
Transverse Leaf Spr
Suspension Type - Rear (Cont.)
Transverse Leaf Spr
Front Tire Order Code
XFG
Rear Tire Order Code
YPS
Front Tire Size
P285/30ZR19
Rear Tire Size
P335/25ZR20
Front Wheel Size
19 x 10.0 in
Rear Wheel Size
20 x 12.0 in
Front Wheel Material
Aluminum
Rear Wheel Material
Aluminum
Steering Type
Pwr Rack & Pinion
Brake Type
Pwr
Brake ABS System
4-Wheel
Disc - Front (Yes or )
Yes
Disc - Rear (Yes or )
Yes
Fuel Tank Capacity, Approx
18 gal 18.0 min 18.0 max
Front Head Room
37.7 in 37.7 min 37.7 max
Front Leg Room
43.1 in 43.1 min 43.1 max
Front Shoulder Room
55.2 in 55.2 min 55.2 max
Front Hip Room
53.7 in 53.7 min 53.7 max
Wheelbase
Length, Overall
176.2 in 176.2 min 176.2 max
Width, Max w/o mirrors
75.9 in 75.9 min 75.9 max
Height, Overall
48.7 in 48.7 min 48.7 max
Track Width, Front
63.5 in 63.5 min 63.5 max
Track Width, Rear
62.5 in 62.5 min 62.5 max
Trunk Volume
22.4 ft³ 22.4 min 22.4 max
Country of Origin
