C6 problem
Old Jan 10, 2022 | 05:45 AM
MPopelier95's Avatar
MPopelier95
Cruising
Default C6 problem
Hello new member to this forum. I have a couple questions regarding the recent problems I’m having with my C6. So first off the car doesn’t want to start up normally which I’ve narrowed down to being the starter. But now my oil PSI is jumping all over and my battery voltage doesn’t hold anything. So is the starter causing all this or is there more to replace
Popular Reply
Jan 10, 2022, 08:06 AM
4SUMERZ's Avatar
4SUMERZ
Sounds like a new battery is required. Do that first before futher troubleshooting.
Old Jan 10, 2022 | 06:15 AM
MPopelier95
Cruising
Default C6 problem
Trying to figure out what is going on with my 13 GS corvette. I know the starter needs to be replaced but the car is now having new issues like battery super low when I get it to turn over and the oil psi drops and jumps when I give it gas. Does anyone have a solution or good idea on what’s going on
Old Jan 10, 2022 | 08:06 AM
4SUMERZ's Avatar
4SUMERZ
Old Jan 10, 2022 | 08:11 AM
4SUMERZ's Avatar
4SUMERZ
You need a new battery. What is the history of that car? Do you drive it, let it sit for days, etc. etc. The C6 platform loves to eat batteries. We need more info on the reason you need a new starter. There is always a draw on the system even if it doesn't get driven, and if it sits too long, the battery will lose enough charge that it will not start the car. Most of us keep it on a tender when sitting for long periods. How old is your battery?
Old Jan 10, 2022 | 08:32 AM
MPopelier95
Cruising
Default Problem
I daily drive the car, there’s a service charging system notification on the dash. The battery is 11/19. The car is completely stock no accidents and etc. just seems like the car is giving out now
Old Jan 10, 2022 | 09:47 AM
Mr. Jean's Avatar
Mr. Jean
I'd start with a load test on the battery and an alt. test. As others have mentioned, keeping it charged can save some headaches for you.
Hope it's as simple as that for you. Might invest in a charger for it, as it is one of the C6 problems. Good luck.
Old Jan 10, 2022 | 12:07 PM
MPopelier95
Cruising
Default Problem
Ok I’ll definitely have to invest in one. Replaced the battery and it’s definitely the alternator bc it’s continuing to drain. But it’s the dealership’s problem now. What brand of charger would you recommend
Old Jan 10, 2022 | 01:47 PM
She_Thicc's Avatar
She_Thicc
Banned Scam/Spammer
From what I've read and understand, the charging system also goes through the power lugs on the starter, so if those are cracking and breaking, which is common, then it would prevent the system from charging.
Old Jan 10, 2022 | 02:51 PM
ruxvette's Avatar
ruxvette
2016 C6 of Year Finalist
You want a maintainer, not a charger. Several good brands...Schumaker, Black & Decker, Battery Tender JR, etc,
Old Jan 10, 2022 | 05:19 PM
v4e2r7t's Avatar
v4e2r7t
Your car is not giving out. You're experiencing routine maintenance and repairs. Your car is fine. Be happy it's winter and not prime driving season.
Old Jan 10, 2022 | 05:32 PM
MPopelier95
Cruising
Default Problem
mare you saying replacing the alternator,starter, and battery is routine maintenance. I daily the car
Old Jan 10, 2022 | 05:36 PM
Mr. Jean's Avatar
Mr. Jean
I use the Ctek 3300 and they call it a charger / maintainer. Mine I use with the cig. lighter plug in.
Old Jan 10, 2022 | 05:39 PM
Mr. Jean's Avatar
Mr. Jean
You had the alternator tested or you're assuming that, because of the drain?
I wouldn't start replacing parts until that's checked.
R&L's C6's Avatar
R&L's C6
On a nine year old car, yes.
Old Jan 10, 2022 | 06:15 PM
MPopelier95
Cruising
yeah had the alternator tested and it ended up being that, the pulley, and the starter
Old Jan 10, 2022 | 06:16 PM
MPopelier95
Cruising
I understand that aspect, I’ve only had the car 2 months in total
Old Jan 10, 2022 | 06:33 PM
Mr. Jean's Avatar
Mr. Jean
Wow! Unusual for three problems at once, but if that gets it fixed, you should be good to go for awhile.
You can do a Google search for chargers/maintainers and see what you like. Good luck.
To C6 problem
Old Jan 10, 2022 | 06:36 PM
MPopelier95
Cruising
Default Problem
yeah that’s what I’ve heard from some buddies of mine that own a C6. The only problem they had was a battery issue. That’s why I’m trying to figure out what cause this chain reaction. I definitely appreciate the advice and input
Old Jan 10, 2022 | 09:23 PM
Mr. Jean's Avatar
Mr. Jean
You're very welcome. Miles of smiles ahead. Enjoy the ride.
Old Jan 11, 2022 | 07:47 AM
Diamonddave60's Avatar
Diamonddave60
Ctek is one of the best
