Installed Stage 1 Cam
I wanted to share my most up to date corvette build. Just installed a mild cam, had it tuned, dyno’d and all the fun stuff. Went with the stage 1 because it’s my daily and I did not want to change the converter.
This cam drives like stock. Does not push through the brakes at stop lights. Cruising and idle manners are like stock. Absolutely loving the power and sound.
Videos & Modifications below!
Performance Modifications:
TSP 1-7/8” LTH
TSP 3” Off-Road X-pipe (catless)
TSP Stage 1 225/236, .629/.615, 114 LSA Camshaft
Corsa Xtreme Axle Back 4.5 inch tip
Vararam Snake Charmer CAI
Stock Converter
All supporting mods (Valve Springs, Pushrods, Gaskets, Spark plug wires, O2 Sensors, etc)
Dyno Results:
470 WHP
465 Torque
Last edited by TheGodOfGlory; Mar 7, 2022 at 07:08 AM. Reason: Change Camshaft brand in title
Cold Start (Click Here)
Walk Around Idle (Click here)
TSP 1-7/8” LTH
Stock Converter
Dyno Results:
470 WHP
465 Torque
TSP Stage 1 is the most cam you should put in an auto car without a converter. Yes, tuning can alleviate a lot of the issues, do your research and talk to the folks over at TSP & BTR so they can help you reach your desired goal.
My buddy put a Stage 3 TSP cam in his car and absolutely hates it, he went from having a great time driving his car to dreading it every day (M6 car). Your only leaving a little WHP on the table between the stages, but driveability and manners change drastically.
Decide before you buy a cam if you want to give up good street manners for performance & choose wisely
