Window regulator
Old Apr 2, 2022 | 07:25 PM
Kenny F's Avatar
Kenny F
2nd Gear
Default Window regulator
I changed the passenger door regulator in my 07 c6. It will not go up past the point it was at from factory. Could something be binding or is it defective?
Old Apr 2, 2022 | 09:03 PM
4SUMERZ's Avatar
4SUMERZ
Welcome to the forum. Check the wiring for the mirrors. It might have come out of the clamp and hanging down thus preventing the window from going up. It happened to me when I removed the mirrors and didn't have the wiring secured. Hopefully, you marked the glass prior to removing the glass and reinstalled it in the exact same place on the regulator.
Just to assure that you closed the door, because if you didn't, the window will not go up all the way. You will also need to re-index the window. That instruction is in the owner's manual.
Good Luck
Old Apr 3, 2022 | 02:14 PM
Kenny F's Avatar
Kenny F
2nd Gear
Defective part. Cable was binding. Thanks for the reply.
To Window regulator
