Steering wheel removal. Simple task?
Old Apr 21, 2022 | 09:55 AM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
Default Steering wheel removal. Simple task?
My C5 was an absolute bear to get the wheel off. After seeing numerous pics of failures I still took it off, slow and steady with the right tools. I had it flat bottomed and wrapped by RedLine. Absolutely loved it.
So C6 wheels, any easier than the C5??
Old Apr 21, 2022 | 10:18 AM
sramzzz's Avatar
sramzzz
Pretty simple, Remove airbag - Use a 1/4" allen in the 2 holes to release. Loosen nut holding steering wheel on but do not remove. Wiggle the wheel and it should come loose. If you search the forum you will find some detailed nstructions with pics but it is really easy.
Old Apr 21, 2022 | 10:57 AM
rbwinston's Avatar
rbwinston
Disconnect your battery before attempting this!!!!
Old Apr 21, 2022 | 11:13 AM
Sledge Hammer's Avatar
Sledge Hammer
Click on the how to tab at the top of the page, click on C6 section, click on interior, page down and click on steering wheel removal. Not a bad job at all.
Old Apr 21, 2022 | 11:46 AM
Jeff T.'s Avatar
Jeff T.
I definitely know the steps! Disconnect battery, wait 10 minutes, side holes to press and release airbag...
I may be wrong but I do not think the steering wheel shaft in the C5 was tapered at all. It took 3 days, I was in no hurry, and popped off with a bang when it finally let go!
The C6 videos look like a little wiggle, wiggle and it will come off. That would be nice!!
Old Apr 21, 2022 | 11:58 AM
SilverC54me's Avatar
SilverC54me
C6 wheel comes of significantly easier than the C5. No puller needed.
Gary
Old Apr 21, 2022 | 11:59 AM
madsonp's Avatar
madsonp
That's all it took to get mine off, real easy.
Old Apr 21, 2022 | 01:50 PM
She_Thicc's Avatar
She_Thicc
Banned Scam/Spammer
Mine was easy. I spent a lot of time getting the airbag cover off, which was supposed to be the easiest part. I just couldn't find the tabs by feel but eventually got it. Tightening the wheel back on was a little tricky without someone to hold onto the wheel but it is doable.
Old Apr 21, 2022 | 02:55 PM
07MontyRed's Avatar
07MontyRed
St. Jude Donor '07 thru '26
NCM Lifetime Member
Agree with all the above. Remembering my C5 experience, I was dreading doing it on my C6 ... took all of five minutes, including removing the airbag (after the battery disconnect). Its easy, no puller required.
Old Apr 22, 2022 | 07:46 PM
cmonkey713's Avatar
cmonkey713
Youtube has some good videos on removal.
Old Apr 23, 2022 | 01:05 AM
rockinSeat's Avatar
rockinSeat
I bought a $20 puller from O'Reillys. I didn't want to force it. The puller makes it easy. Check my post to the steering wheel thread Here
Old Apr 23, 2022 | 01:47 PM
Iowa's Avatar
Iowa
10 minute process. The wheel comes off by hand after a few taps. When loosening the nut don't take it all the way off. Take it most of the way and then pull on the steering wheel to get it loose. Once the wheel is loose finish removing the nut.
Old Apr 23, 2022 | 02:09 PM
Jason71's Avatar
Jason71
I know all the info posted here and everywhere else says “don’t need a puller”. I have swapped mine out twice, and I used a puller each time. Autozone has their loaner program for their tools, so I just went and borrowed a universal puller. It made the process super easy peasy.
I jerked, yanked, and pulled mine as hard as I could and couldn’t get it to release either time. I figured I wouldn’t need the puller the second time since I had just had the wheel off not too long before, but it was stuck on there solidly and wouldn’t release.
Since you can borrow a puller for free, I would personally go that route.
YMMV
Old Apr 23, 2022 | 02:23 PM
She_Thicc's Avatar
She_Thicc
Banned Scam/Spammer
My wheel literally just slipped off once I had the nut off. Didn't take any force. Guess I got lucky.
Old Apr 23, 2022 | 02:32 PM
Dutch08's Avatar
Dutch08
Yes, easy! But note that the 2005 has 4 release holes.
Old Apr 23, 2022 | 07:30 PM
z06clif's Avatar
z06clif
Make sure the battery is diconnected and you put it back straight. Comes off easy. No puller requiered
Clif
To Steering wheel removal. Simple task?
