08 corvette
Old May 31, 2022 | 04:07 PM
dave08's Avatar
dave08
2nd Gear
Default 08 corvette
automatic shifter will not shift out of park, any thoughts? Thanks
Old May 31, 2022 | 05:20 PM
ls1121's Avatar
ls1121
St. Jude Donor '14-'15
Well you can start here, there a ton of threads on this topic, search is your friend.
https://www.corvetteforum.com/forums...pair-time.html
Old May 31, 2022 | 07:21 PM
gilbybarr's Avatar
gilbybarr
Common problem that eventually crops up and these models. As noted, threads on how to fix it yourself. When my 2008 went bad at around 17,000 miles (and 11 years of age) it would not go into reverse or park. I didn't want to mess with it myself, so I just took it to the dealer. But, that "it aint cheap." Good luck with getting it fixed.
Old May 31, 2022 | 10:04 PM
buckmeister2's Avatar
buckmeister2
Dave, welcome to the forum. I recommend you spend 15 or 20 minutes a day viewing this site. You will find out things about your car that will help you, as you would have with this issue. There is no other forum with this much activity, and this much knowledge.
Good luck with your car. Hope to see you here more often.
Old May 31, 2022 | 11:03 PM
1320#me's Avatar
1320#me
My thread for this topic is fresh. Check it out. Great advise from people that know.
Old Jun 1, 2022 | 04:44 AM
Holster Maker's Avatar
Holster Maker
Here are a few links of them. Very easy job, just cut the little plastic pawl and done for ever. One hour job without ever doing it before.
https://www.corvetteforum.com/forums...k-in-park.html
https://www.corvetteforum.com/forums...anymore-2.html
https://www.corvetteforum.com/forums...e-found-2.html
https://www.corvetteforum.com/forums...-assembly.html
To 08 corvette
