Weatherstrip question
Old Jun 2, 2022 | 08:30 AM
Aardwolf's Avatar
Aardwolf
Default Weatherstrip question
There’s an odd part sticking up on both sides of the front top windshield. Should this be trimmed off or stuck down?
Old Jun 2, 2022 | 09:12 AM
jbc1995fb's Avatar
jbc1995fb
I wouldn't cut it. Remove your top and see if it tucks back down.
Old Jun 2, 2022 | 09:13 AM
Klawp's Avatar
Klawp
I have this same issue. Dang thing always catches on my rags.
Old Jun 2, 2022 | 10:28 AM
C6ToGo's Avatar
C6ToGo
Mine too, but not bad enough to worry about fixing yet.
When I do, will soften it up with a heat gun (or hair dryer) and have some good adhesive ready plus tape to hold it down
Old Jun 2, 2022 | 12:03 PM
SixAddict's Avatar
SixAddict
That trim piece is part of A pillar, I just had mine (A pillar) replaced with windshield, yes insurance will cover new A pillar along with windshield if you have glass coverage. That trim piece should be even with top of A pillar. It actually comes off quite easily or you could use soapy water and slide it back down to even or just get a new rubber trim piece.
The A pillar comes off quite easily also.
Old Jun 2, 2022 | 02:51 PM
PCMusicGuy's Avatar
PCMusicGuy
Definitely part of the A-pillar. Should just slide back down. They do tend to move around after a while.
Old Jun 2, 2022 | 03:55 PM
dr_gallup's Avatar
dr_gallup
Cool, I learned something today. Mine only stick up a small amount but will see if I can move them down.
Old Jun 2, 2022 | 04:08 PM
schizcat's Avatar
schizcat
Happens after driving for a bit, car washes, etc. Just need to slide it back down. It should sit flush with the bottom and top of the pillar.
Old Jun 2, 2022 | 05:44 PM
Aardwolf's Avatar
Aardwolf
Awesome thanks, I will give it a try!
To Weatherstrip question
