Head Unit Upgrade Issues
Old Jun 18, 2022 | 05:02 PM
TorchRedFred's Avatar
TorchRedFred
Originally Posted by brains904
So, basically, I need to learn how to read better? I'm not sure how I overlooked the appropriate wiring harness to use, but nevertheless, thank you all for your help. I'll swap it out and report back. Thanks again
It's actually not your fault. These companies give out generic information that is incorrect. Axxess assumes that because a car has a Bose sound system option, that the Bose system has the amp and the base sound system doesn't have an amp. And then they incorrectly list multiple interfaces as being compatible. Unlike some other cars, the Corvette has a factory amp for both the base sound system and also the Bose system. So Axxess is incorrect when they list a wiring harness that is not compatible with a factory amp. All C6's came from the factory with a factory amp, and you would use the same interface and follow the same directions for all C6's, Bose or non-Bose.
Old Jun 18, 2022 | 07:10 PM
madsonp's Avatar
madsonp
Originally Posted by Landru
Member 'Madison' seems board's go-to guy where audio/video is concerned.
Find him, send a PM requesting his input.
Otherwise try posting this in 'Audio/Electronics' forum: Audio/Electronics - CorvetteForum - Chevrolet Corvette Forum Discussion
G/L
Originally Posted by Sledge Hammer
I think the member you are referring to is "madsonp".
Cool, I'm a go-to-guy now, thanks for the vote of confidence guy's.
Old Jun 18, 2022 | 10:36 PM
Boss 57's Avatar
Boss 57
You know your stuff for sure, I'll say you have a refreshingly technical
Old Jun 19, 2022 | 02:00 AM
TorchRedFred
Pete, you da man
Old Jul 13, 2022 | 09:41 AM
brains904's Avatar
brains904
Cruising
Glad to help, let us know how things turn out, or if you have any other issues.
I finally had time to tear the car apart and start over... Swapped out the wrong interface for the RP5-GM11, and magically everything works the way it's supposed to. Amazing what happens when you use the right parts... Thanks for your help!
Old Jul 13, 2022 | 10:08 AM
madsonp's Avatar
madsonp
Glad you got everything working right.
Old Jul 13, 2022 | 12:42 PM
TorchRedFred
Thanks for coming back and updating the forum. This could jelp someone in the future. Glad you got it working correctly.
