I have an issue and it’s not clear where is this issue coming from.
when RPM goes above 2000 a vibration starts and the more rpm the faster it becomes, no sounds just vibration.
I thought it was the drive shaft so I changed driveshaft bearings and rubbers but still got same issue.
I’m not sure it’s from the engine because if it’s from the engine it would show knocks I guess..
Whether I engage or disengage the clutch it’s still vibrates as if it’s going to blow up!
When you are stopped in neutral and rev the engine with the clutch in, does it vibrate?
When you are stopped in neutral and rev the engine with the clutch out, does it vibrate?
Yes it vibrates when clutch in and out. I tried to press the clutch more than once in case in if it’s not release 100% but still the same..
So, it is not speed-related, at all? Only when above 2k rpm, no matter what speed? And, it happens in neutral, clutch in or out...hmm. Sounds like it has to be engine, or an accessory on the engine. I would not be driving it at all until I found out where the noise is from. If it is an "engine vibration" you may damage it more by driving.
That eliminates the driveshaft and gearbox from suspicion. With the car stopped and the clutch disengaged, they're not moving.
Press the snowflake button to disengage the A/C compressor and see if it helps. It's an easy test to try.
Look to see if the harmonic balancer is wobbling.
Remove the serpentine belt to eliminate all the accessories. You'll get a charging system error and no coolant won't be circulating so don't run the engine long.
Anybody have thoughts about motor mount?
Actually my power steering is wobbling a bit but I don’t think the power steering would vibrate the whole car! Would it be the reason!?
But when A/C is off it means that compressor is not working right?
Correct me if I’m wrong.
I agree with samk6, I think you should check your harmonic balancer. In time the rubber in the balancers can start to come apart and they can let the weight slip. This can cause a definite vibration that follows the engine RPM's. I would give it a good inspection and then I would look into other components.
