'09 C6 - Ongoing electrical issues that cannot be resolved
I checked the connectors under the passenger side carpet and all of them are clean and tight. I also have, new today, the inability for the horn to honk upon lock (did not change this in the DIC) but now that both headlights are working, can drive at night.
These cars certainly do seem to find the “path of least resistance” when there are electrical issues, leading one to believe multiple systems are failing, but I do agree - the comments so far on checking grounds and connections have put me on the right path so far.
For those who are electrical experts, what does it mean when you go to lock the car from the FOB and it just flashes all door lights and clicks a relay back and forth multiple times? Is the RCDLR the next thing to check?
Also, my battery is again at 11.7V after being in the car overnight, but stays above 12 when you charge it with a tender and take the battery out of the car.
I’m willing to believe it’s the aftermarket stereo, just odd how it worked fine for 8 years and even after a head unit swap to another Nav head unit (also aftermarket) the same issues are there. I didn’t try a new RP5-GM11 harness or the factory (OEM) radio yet, work had me pretty swamped last week.
Apparently thing wasn't turning off as it was supposed to.
IF NOT using OnStar, pull the fuse.
Eliminates one possible issue.
Since I regularly take the car on trips where services are limited, such as through rural Nebraska, would it be a good idea to carry some sort of basic tools (such as a voltmeter) in case these issues crop up again? Also thinking of getting a decent code reader.
With the number of issues cleaning the grounds have solved, I think this should be regular practice every 160-200k miles even on C6’s that aren’t experiencing issues. If anything, I will probably have to do this again at 340-360k miles anyways.
Speaking of, what are some things that should be done at or before 200k? I don’t have a 200k service in my manual (ends at 150k), and want to keep up on the maintenance so the car can go the distance. Rear end flush? I’m getting close to 200k and want to have a reliable, dependable car.
Thanks!
I have a 2009 C6/1LT/auto that has served me well for many years. I am the second owner and have driven the car daily since 2014 in which it had 68k miles. The car has around 170k miles now and has developed some strange electrical issues. The car has been to several shops and dealers who have thrown a boatload of parts at the vehicle, only to have the problems return. As of yesterday, the car has experienced:
- Entire radio display is dark and will not even provide backlighting to the buttons when the headlights are on.
- Navigation head unit is non-functional and even the CD stuck in the stereo refuses to be ejected.
- One headlight (usually the driver side) goes out when the Left turn signal is activated.
- Map lights and other lights stay on even after leaving the car, but lock/unlocking cures this (sometimes).
- Alarm going off even after you've unlocked the car with the factory keyfob/remote.
- Unable to pair a second keyfob/remote using the procedure in the owner's manual.
- Random lights such as tail lights, reverse lamps, and other lights on when parked.
- Interior bulbs burning out at random (driver side footrest, DIC buttons, HVAC defrost).
The car does have an aftermarket stereo in it, installed with a PAC RP5-GM11 interface adapter, but that has been installed since 2014. Just to rule that out, I swapped in a different aftermarket stereo just to eliminate the existing Alpine head unit (in case it had an internal short). I can try putting the OE stereo back in, which would enable the factory XM and OnStar features, but am not sure if the radio is the culprit - if it is, why did it take 8 years to occur (and there are no shorts on the harness, connections were soldered and not crimped).
Today the car showed all of the same electrical issues with the driver side headlight turning off regularly when the turn signals were enabled. Multiple times I would hear relay noises that shouldn't be happening, even after I opened the hood. The fuel pump relay (#55) is very hot to the touch, and the battery isn't charging after a 20 minute drive - when put on a battery tender it showed the battery was depleted. Voltage when sitting is around 12.1-12.3V right after shutting off the engine.
I'm afraid to take this thing back into a shop again and receive thousands of dollars of parts thrown at it and no resolution. The only thing I can think of is try cleaning connectors/grounds, put the factory stereo back in, and then hope I find a decent repair facility that isn't going to play the "keep replacing things until it fixes the problem" game because that's all most shops have done so far.
If you had an excellent condition C6, with only this minor problem, what would you do?
Edit: I may have had “Lost Communication with BCM” at one point but the dealer cleared and it has not come back, go figure.
Thank you C5 Diag!
I have the location of all 12 in a PDF. I'll attach it here. I remember dealing with an electrical problem that came from a loose ground on one of the REAR chassis grounds. So I encourage that all of them be checked.
The good news is: As big as the drain is, it should be fairly easy to find for someone who knows what they're doing. Great idea to take the car to one of the recommended diagnostic guys and give your dealership some time off. Sounds like they have done all they can do at their pay grade.
Does GM not have service recommendations for 200,000 mile service, 300,000 mile service, etc. for this car? Not sure if I need tie rods, wheels are out of round, or if I need other front end components such as control arms. Wish there were some “replace at XYZ miles” guides which seem to be missing from the manual.
My ‘09 manual just covers stuff like spark plugs and fluid changes, but not much about regular mechanical maintenance (tires and alignment are in the manual, but those seem to be the obvious things to replace).
) You can set up a small kit with whatever you want, but absolutely don't lave home without it.Does GM not have service recommendations for 200,000 mile service, 300,000 mile service, etc. for this car? Not sure if I need tie rods, wheels are out of round, or if I need other front end components such as control arms. Wish there were some “replace at XYZ miles” guides which seem to be missing from the manual.
./QUOTE]
I would seriously consider replacing all of the rubber suspension components, namely the upper and lower control arms and the shock bushings. I would also look at the motor mounts to see if they are leaking. From there, wheel bearings and possibly the shocks themselves and tie-rod ends and ball joints. It would probably be a good idea to have the drive shaft joints looked and the sway bar mount bushings - also rubber. Basically any rubber in the suspension and drive line you can find.
./QUOTE]
Appreciate those who have 200k+ and knowledge of how to keep these cars running. I'm hoping to have this car for 350,000 miles and want to keep up on all the necessary maintenance to get it there.
just thinking of what else would have such a far reaching effect. but i also agree with what some others have mentioned. checking your grounds would be the minimum thing to check.
don't you just love computer based vehicles? the old suck, bang, blow doesn't carry as much weight as it used to.
good luck though!
I have cleaned several grounds, removed the aftermarket radio (ran the car with no radio except PAC RP5-GM11 harness to prevent the car from throwing faults), and think I’m down to one or two things for parasitic draw.
I could use a clamp on ammeter and check each circuit, but want to know if it’s even worth my time to do that for the OnStar module as it’s no longer capable of being used.
My thought is might as well disable it as a troubleshooting step.
Thoughts?
Next, move to the fuse box Start by pushing the engine compartment upper fuse block from the lower block, clean the upper fuse block and lower blocks connectors, touch of dielectric grease, and reinstall the upper fuse block and make sure that the fuse bolt positive terminal nut is tight when you reconnect the battery cable to it. To add here, it helps to pull all the fuses and relays to give their U connectors shot of electrical contact cleaner as well.
Now on too the battery cables. Make sure you clean them with a wire brush and put dielectric grease on both cables. Underneath the battery tray there are two main grounds I recommend cleaning.
After that move down to the starter. The main issue is the starter solenoid. The plastic melts overtime and causes a weak connection. If all looks ok disconnect the the nuts and clean them and add a dab of dielectric grease. Also check the ground on the engine block is tight and not corroded. This is a super important ground to keep clean and connection tight.
Now let’s move inside to the passenger footwell. Unplug the onstar since it causes parasitic draw. Next, the blue connectors on the bcm. Unplug them and clean with cleaner and add a dab of dielectric grease. Plug them back in.
On to the ecm in the fender. You’ll need to remove the tire. Unplug all the wires and give them all a shot of cleaner and dab of dielectric grease. Plug back in. Clean the grounds there as well.
*You can also do this to all the connections behind the center console. RCDLR, Radio, HVAC. In fact everything through the entire car. Since Gm didn’t add any dielectric grease from
factory to any connection or ground.
Now you can put a new battery back in lol
***use crc red can for the cleaner.
I have fixed an odd issue on break rear lamps which never lighted off by only cleaning BCM plugs like said above by Petera90.
