No valid disc
Old Sep 30, 2022 | 11:26 AM
woodvette03's Avatar
woodvette03
Default No valid disc
Getting a "no valid disc" error on my CD player in my 2012 GS. Tried several different discs. They are store bought music CD's. Anyone seen this before? How do I fix it?
Thanks in advance.
Old Sep 30, 2022 | 12:50 PM
FatsWaller's Avatar
FatsWaller
A dirty lens in the player can cause this problem. If so, this might work
Amazon Amazon
Old Sep 30, 2022 | 01:11 PM
dmaxx3500's Avatar
dmaxx3500
go buy a disc cleaner
Old Sep 30, 2022 | 05:04 PM
gdmoore01's Avatar
gdmoore01
Probably a dirty/dusty optical read head. Get a can of compressed air & use the included tube to direct the air into the DVD/CD slot. Try this out and report back on results.
Good luck...GD
Old Sep 30, 2022 | 05:20 PM
I M Tweety Bird's Avatar
I M Tweety Bird
Mine did the same thing....nothing that I tried worked until I bought another unit and put it in ....had to have the dealer marry it to the car though.
Old Nov 3, 2022 | 12:10 PM
woodvette03
so i used a the lens cleaner disc and it will not recognize that. also blasted air inside the unit and still nothing. guess it is dead?
this seemed to have happened right after i had the battery out of the car for a few days to check/charge it. not sure if that matters.
Old Nov 3, 2022 | 12:32 PM
Corvette_Ed's Avatar
Corvette_Ed
Sounds like a replacement is due. This would be a good time to get a modern aftermarket head unit.
Old Nov 3, 2022 | 01:00 PM
Geoff13IOM6GS's Avatar
Geoff13IOM6GS
repeatedly named one of the best upgrades to be done
Old Nov 3, 2022 | 08:05 PM
JasonAndrew's Avatar
JasonAndrew
Mine does it too, 2012. GPS doesn't do **** either. Post up a recommendation for a head unit.
Old Nov 3, 2022 | 09:50 PM
Slojack's Avatar
Slojack
I put a Kenwood DDX67065S in my 2006 convert. This model supports CD's and has provisions for both front and rear cameras ( another upgrade that you will be glad to have) The Kenwood also supports Car Play, Android Auto, you will be able to use your phone for GPS and music, So, call Crutchfield and let them know what you are looking for in a new head unit.They will help you out and have great tech staff that will help you with any installation problems (I called four times) Oh, they are expensive but you'll be happy with the results.
Old Nov 3, 2022 | 11:16 PM
FatChance's Avatar
FatChance
If you are getting a replacement HU, determine if you want a quality name brand or cheaper off brand, CD/DVD capability, wired or wireless Carplay and/or Android Auto, XM, Onstar, Front or rear USB, touch screen, vendor GPS or smart phone based GPS, Bluetooth, a volume ****, one or more camera and/or A/V inputs, factory or aftermarket amp, subwoofer and/or speakers, floating or fixed screen, steering wheel controls, price range, self or paid installation, then call Crutchfield or log onto their website and follow their recommended advice. You get what you pay for but only pay for what you need/want.
I got a JVC KW-V660BT (made by Kenwood) with a 2 year warranty on sale 2 weeks ago from Crutchfield with their mounting system and pre-wired harness because I wanted CD/DVD, wired Android Auto for music/apps/Google Maps GPS, Bluetooth, microphone for phone calls, no volume ****, no XM or Onstar, rear USB (with flush mount extension), one camera and one A/V input (2 cameras bought from Amazon), keeping factory Bose amp/speakers, fixed screen, no steering wheel controls (none on my 06 C6), touch screen, that I would install myself for under $500, total. I knew what I wanted, what I needed, what I wanted to pay and got exactly what I wanted and needed.
To No valid disc
