Innova scan code readers
Old Nov 23, 2022 | 08:18 PM
FatChance's Avatar
FatChance
Default Innova diagnostic code scannners
I am looking at an Innova 3160rs diagnostic cose scanner on sale on Amazon for $211. Do any of you have something similar? I also looked at their 5510, but they say it is the same thing. What are your opinions on such a device or something similar?
Old Nov 23, 2022 | 10:54 PM
208vette's Avatar
208vette
I have an older model, the 31603. It's been very useful for the few times I've had to use it on my vette and 4runner. If you like to figure out issues and fix them yourself when possible, it's definitely worth it.
Old Nov 24, 2022 | 01:20 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
IMHO “code readers” are useless…you are better served buying something like this Launch which has full bidirectional capability and is cheaper too…Launch makes some excellent scan tools !!
Old Nov 24, 2022 | 08:12 AM
robert.m.kalis's Avatar
robert.m.kalis
Just looked for the launch scanner and it's on sale at Amazon, black Friday sale, Happy Thanksgiving y'all
Old Nov 24, 2022 | 08:36 AM
C5 Diag's Avatar
C5 Diag
WOW !!…a fully bidirectional scan tool for less than $100.00…that’s unheard of !!!
Old Nov 24, 2022 | 11:19 AM
FatChance's Avatar
FatChance
To be fair, the Innova 3160RS is a lot more than just a "code reader" and will work on all newer vehicles, not just GM vehicles. That said, I just ordered one of those $94 Black Friday deal Launch X431 GM scan/reader tools mentioned above for my C6. It seems to be too good of a deal at that price to not give it a try, even if I apparently can't use it on our Tacoma or Lexus.
Old Nov 24, 2022 | 11:28 AM
C5 Diag's Avatar
C5 Diag
Originally Posted by FatChance
To be fair, the Innova 3160RS is a lot more than just a "code reader" and will work on all newer vehicles, not just GM vehicles. That said, I just ordered one of those $94 Black Friday deal Launch X431 GM scan/reader tools mentioned above. It seems to be too good of a deal at that price to not give it a try, even if I apparently can't use it on our Tacoma or Lexus.
Yes, I’m not familiar with the Innova tool but when you said it was a scan “code reader” a code reader usually just reads OBD2 DTC’s….they may have other functions I don’t know about…Techstream is the OE factory scan tool to Toyota, Lexus and Scion.
Old Nov 24, 2022 | 06:47 PM
FatChance's Avatar
FatChance
Overview of information about the Innova 3160rs from the Amazon website:
The Innova 3160RS OBD2 Scanner is an easy-to-use tool that packs high-end maintenance and service functions typically not found in DIY scan tools. Unlike other code readers & scan tools, it is more than just a OBD2 Scanner diagnostic tool it is also a ABS bleeder scan tool, check engine code reader, abs code reader, SRS scanner, and full system scanner with battery reset, airbag light reset, oil light reset, reset check engine light with smog check. Perform maintenance like a pro with ABS bleeding, electronic parking brake retract, transmission temperature, and TPMS data. Use necessary advanced caliper service functions like electronic parking brake retract and ABS brake bleeding on modern vehicles. View transmission temperature to verify in real-time when the transmission fluid is within operating range for aid in diagnosis and fluid changes. Live data allows you to see essential information about your vehicle (e. g. RPM, oil temp, etc.) in real-time to aid in diagnosis. Reset your oil maintenance light and view important maintenance information, like oil level and oil life, necessary for servicing your vehicle. Find out quickly if your vehicle will pass an emissions test with the built-in smog check LED indicators. Packed with professional-grade features and benefits, Innova’s new range of tools come with Bluetooth and WiFi technology and pair seamlessly with the all-new RepairSolutions2 diagnostic app. Go beyond simple fixes, with ASE master tech verified fixes. View the professionally recommended repair and parts needed for your vehicle, as well as estimated shop price, view maintenance schedules, receive technical bulletins recalls, and more. It is the perfect diagnostic car scanner for all cars compatible with exactly what you need to keep your car on the road. Put your trust in Innova OBD2 Scanner because our California-based, ASE-Certified Customer Support Team is always glad to assist you to keep your scanner for car running.
Top Features Included:
  • RepairSolutions2 App: Get verified fixes, the exact part required for repair, maintenance schedules, and more; get the knowledge to fix your vehicle; includes unlimited free vehicle health reports.
  • All-System Network Scan: Scan beyond check engine, powertrain, ABS, and SRS modules.
  • Comprehensively read and clear all ECU modules and their trouble codes.
  • Electronic Parking Brake Retract / ABS Brake Bleeding: Necessary advanced brake caliper service functions for modern vehicles.
  • TPMS Read: Gives the ability to read and diagnose tire pressures and sensor data.
  • Transmission Temperature: Verify in real-time when the transmission fluid is within the correct operating range for aid in diagnosis and fluid changes.
  • Battery Test/Battery Reset: Ensures your vehicle is programmed correctly to accept a new battery and perform system tests when installed.
  • Read Hybrid Battery Cell Voltage: Diagnose battery and charging issues on hybrid vehicles.
  • Oil Light Reset / Oil Level / Oil Life: Reset your oil maintenance light and view important maintenance information necessary for servicing your vehicle.
  • Live Data: See essential information about your vehicle in real-time (e.g. RPM, oil temp, etc.) to aid in diagnosis.
  • Smog Check LED Indicators: Find out immediately if your vehicle will pass an emissions test.
  • Optional OBD1 Coverage: Compatible with Innova OBD1 accessory adapters. (Sold separately)
$211 Black Friday sale price on Amazon. Not affiliated in any way, but I am just looking for a good Obdii tool. There is a lot of overlap with the Launch X431 mentioned above, so maybe they complement each other for a DIY amateur mechanic at about $300 for both?
To Innova scan code readers
