Help Identify Part
Old Dec 11, 2022 | 08:17 PM
rmedina's Avatar
rmedina
Default Help Identify Part
Hey guys.. Need some help identifying this part on the engine under the alternator. Looking at the pics it obvious I need to change it. Thanks in advance..
Old Dec 11, 2022 | 11:04 PM
Patsgarage's Avatar
Patsgarage
Coolant temperature sensor, but I would change your valve cover gaskets first.
Old Dec 11, 2022 | 11:45 PM
DrKrieger's Avatar
DrKrieger
Agreed......leaky valve cover gasket first, then change the sensor!
Old Dec 12, 2022 | 06:29 AM
StayinStock's Avatar
StayinStock
2023 C6 of the Year Winner - Modified
Indeed coolant temp sensor, however if its working no need to change it, just fix that valve cover leak. Once you do spray everything down with some brake clean.
Old Dec 12, 2022 | 09:25 AM
rmedina's Avatar
rmedina
Outstanding.. Will do. Thanks again guys.
Old Dec 12, 2022 | 01:31 PM
rmedina's Avatar
rmedina
Thanks again for the input. I'm about to get started, but it appears I'm missing a bolt or is this normal?
Old Dec 12, 2022 | 01:33 PM
StayinStock
Nope just an unused mounting boss, could be something that was utilized on a different model in a different vehicle, all LS motors share similar valve covers. The bolts that hold down the valve cover are the 4 in the center.
Old Dec 12, 2022 | 02:21 PM
ApexClone's Avatar
ApexClone
And don't overtighten the valve cover bolts! They only require 106 in lbs (8.8 ft lbs).
Old Dec 12, 2022 | 05:39 PM
rmedina's Avatar
rmedina
Thanks again guys.. I appreciate the infomation.
To Help Identify Part
